Results 1 to 13 of 13
Thread: TC vs FC on Walmart Test
    Guest
    Hi there! I am new to TFP and a new pool owner. We set up our new pool on 7/13/13, added the salt the next day, waited 24 hours with the pump running and then turned on the SWG per the instruction manual. I bought the cheap 3 way test from walmart you all recommend while I wait for my TF-100 to get here. My question is, what is total chlorine?...that is what the test results give me, not FC like your article says to be testing for. Or am I confused? lol Thanks in advance for your help!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: TC vs FC on Walmart Test
    Welcome to TFP!
    Total Chlorine is Free Chlorine plus Combined Chlorine. If the water is in good shape, TC is very close to FC.
    38,284
    Welcome to TFP!!!
    Where did you see a recommendation for a 3-way kit from Walmart? There is a 6-way that is ... OK.
    You will be much better off with the TF-100
    Guest
    Welcome to TFP!!!
    I just assumed the 3 way would be fine to get an inital idea of PH and Chlorine until my TF-100 gets here on Friday
    Guest
    Quote Originally Posted by JohnT
    Welcome to TFP!
    Okay, thanks
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    It is, it's basically the same as the K-1000 that will come with the TF-100. It's fine for ballpark Chlorine and good for PH.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Crystal0922
    Have you read these pool school articles yet?:
    Guest
    Quote Originally Posted by linen
    Yes, I have read through almost all the articles in Pool School. I don't have all the info memorized yet, but I keep referring to the articles that pertain to my situation the most, such as the two you listed above. I am so glad I found this site, it is very helpful!
    Guest
    Linen,
    Can I ask why you have the copper bars disconnected on your SWG? I've noticed several people that say they have done that...
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    The copper is slowly deposited in the water to act as an algacide and will build up over time. Excess copper will turn the water a clear green, deposit stains on the liner, and causes blond hair to turn green. When you maintain your pool with proper chlorine levels you do not need an "algacide" and don't have to deal with difficult to remove stains and managing the copper in the water with sequestrants. The only way to remove the copper from the pool is to drain and refill with fresh water.
    Love TFP? Become a
    TFP Supporter!
    Guest
    Quote Originally Posted by zea3
    How do you disconnect the copper bars?
    Jul 2009
    Houston, Texas
    9,380
    You can just unplug the connector or you can remove the bars themselves. You can find instructions to completely remove the copper bars here.
    Love TFP? Become a
    TFP Supporter!
    Guest
    Thank you
