Results 1 to 7 of 7
Thread: Green Tint
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    Green Tint
    I have everything in line as far as numbers, testing just done and had 1 fc low but normal for overnight loss 0 cc 7.5 ph 90 ta and 40 cya.
    when I add bleach the water turns green, if I let all the chlorine go out the water clears up but adding the 2 quarts to bring the fc up to the 4 tints the water, water pulled from fresh water stream in my front yard so there shouldn't be any metals in it to be an issue.......... any ideas
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Green Tint
    This sounds like metals even if the water came from a stream, what feeds the stream? Have you had a history of adding algaecide that contains copper?
    Ike
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Green Tint
    I agree, that sounds like metals. However are you saying your FC level is 1 ppm? If so, get it up to at least 3 ppm or your clear tint could change into a cloudy algae mess.
    How long have you had the tint?
    One thing you could try before adding a metal sequestrant is to drop your ph down to 7.2 or so and see if the tint disappears.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Green Tint
    Not meaning to pile on, but it really sounds like metals. I also suggest lowering the pH, then you should go ahead and use a sequestrant. Maybe it will be a one-time application, who knows.
    You can do a lot of sleuthing to determine the culprit, but in the interim, you need to have chlorine in your pool
    You're done SLAMing when:
    259
    Re: Green Tint
    Quote Originally Posted by Isaac-1
    Ike
    A Reservoir that supplies water to the town is what feeds the stream, used it every year and never had this issue, never used any algaecides only the BBB
    Quote Originally Posted by linen
    Just this season just opened before the 4th never had issue before
    Just got ph up to 7.5 from the 7.2 thought that might have been it
    Confer E9120 Steps
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Green Tint
    Perhaps the town added some type of copper containing algaecide to the lake
    259
    Re: Green Tint
    Boy I hope not.
    Confer E9120 Steps
