Results 1 to 16 of 16
Thread: dirty rural water makes dirty pool water
    Jul 2013
    McAlester Oklahoma
    17
    IST TIME POOL OWNER. Our tap water is always slightly yellow/cloudy. (Or worse). My new AG pool water started out to look like that but the deeper it got,It looks like lake water. Have: added 210lbs salt, 4, 2# bags of Balance and Restore for Salt systems 32oz of Shock and swim (non chlorine)
    Ran sand pump 48 hrs then today I started intex salt water system. (On boost mode).now I've come here because nothing seems to help.
    These are all the tests I have at this time:
    Copper 0
    Free chlorine 5ppm
    Alkaline 40ppm
    P.H. 6.2
    Refilling pool isnt an option because thats the water we live with coming out of faucet.
    I promise ill go to pool school, but, for right now I'd like to know if there's hope.
    AG intex pool 12x24x52" apprx 8500 gal. Intex sand filter, Hayward pump 1 HP, 60GPM with added SWG system, Water Tech Pool Blaster Max Vac. (Iron in faucet water)
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: dirty rural water makes dirty pool water
    What sort of tests are you using, yellow is likely metal in the water. Also you need to raise your pH
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Is this well water or provided by a utility?
    Jul 2013
    McAlester Oklahoma
    17
    This is not well water. Its maintained by utility's water co. Also the test strips im using came with the pool. Is there a specific product to raise ph?
    I notice my signature isnt showing up..any advise?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    You can use borax, soda ash, or washing soda to raise pH. You may want to have the water tested for iron. If the test is positive you can add a sequestrant to take care of the discoloration of the water.
    Love TFP? Become a
    TFP Supporter!
    SW Indiana
    9,199
    Quote Originally Posted by Lonwat
    I suspect your utility needs to flush their lines. Often this is a problem if you live near the end of a line. If you complain, they may be able to open the flush hydrant and help with your household water. That won't do anything to fix what's already in the pool though.
    22,553
    Since it's a public utility you can get a water report and find out what's in the water. They are required to give you one if you request it.
    As JT said, I'd complain about it and maybe a flush out will help in the future.
    Jul 2013
    McAlester Oklahoma
    17
    Thanks so much. I will get water report from utilities and get better more in depth test strips. Think ill go to the local pool guy and take a water sample.
    Questions: do you think my 1600gph sand filter is large enough
    Can we install an ozonator with our Sw system?
    SW Indiana
    9,199
    No need for it. There are much better things to spend the money on. Like a Margaritaville Frozen Concoction Maker!
    Jun 2012
    Howell, NJ
    977
    There is no such thing as reliable test strips. The only reliable test kit is a drop based one, the best of which is the K-2006 or TF-100. Also, ozonators are not needed in an outdoor pool, and I believe they in fact can increase chlorine demand. As far as your filter, I have no idea about filtration.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Don't get test strips, there's a test kit comparison in pool school, get one of those. The 1600 should be okay for that size pool.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jun 2013
    Fallsburg, NY
    258
    You very likely have high iron in your water, we had the same issue with our rural municipal water, I used hth Metal Control in mine and it cleared up within about 12 hours.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    Jul 2013
    McAlester Oklahoma
    17
    Pool store tested and had way too much iron. Put in their suggested "metal out" but 24 hours later and no change. Backwashed today and the water that came out was filthy.im kind of at a loss at what to do next. What is a sequestrant...does walmart sell it?.
    Jun 2013
    Fallsburg, NY
    258
    What's in Metal Out? there are only a few chemicals that are really effective sequestrants. see http://www.troublefreepool.com/pool-...metal%20stains I used hth Metal Control which is a derivative of phosphonic acid, and it worked for me.
    Jul 2013
    McAlester Oklahoma
    17
    Finally got chemicals balanced. I found a product called "sink and swim" for all the metal. It actually cleared my pool but left a yellowish powdery substance on pool floor. It says to vacuum this up but when I go to vacuum it seems to stirr it up more than it vacuums. I bought the water tech pool blaster max vac. Which all reviews seemed positive. Any suggestions or is it just a matter of continuing to vac...settle. ..vac
    Jun 2013
    Fallsburg, NY
    258
    Vacuuming with that vacuum won't do any good, the fine particles will just pass right through the mesh bag. You need to use a suction side vacuum to vacuum to waste or through the filter.
