Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Water analysis test - HELP!
    May 2008
    California City, CA
    51
    OK, I had my water tested at Leslie's because I've had trouble keeping my Free Chlorine level up. Jasonlion said my CYA was non existent and that's why the FC wouldn't hold. I added 4 lbs of CYA 4 days ago and have been adding bleach every night but still can't get the FC over .5. By the way, I have a 16,000 gal in ground fiberglass pool with a SWG and chlorinator running at 100% for 4 hours per day. My numbers are as follows: FC: .5 / TC 2 / PH 7.2 / TA 100 / CYA 27 / and here's a new one for me, they said my phosphates were through the roof at 2500! I don't even know what that is or what to do to lower it. They guy at Leslie's also told me that my CYA level is only slightly low and should be holding FC just fine. He said I should use 2 - 3 lbs of non chlorine shock to "free up" the chlorine. Since I don't think those guys know what the heck they're talking about, I thought I'd come back to all of you knowledgable people here at TFP and see what my next move should be. Any ideas???
    Templehb - 16,000 gal fiberglass inground pool, Aquapure 1400 SWG, DE filter.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Are you adding bleach according to the pool calc? And have you adjusted your numbers based on the higher CYA? You need to add more chlorine to reach shock level at 30 (27) than you did at zero.
    Shocking with bleach will "free up" your chlorine just as well and much cheaper than the "non-chlorine" shock.
    I'm sure someone else will chime in on the phosphates, theres another thread tonight about that too... I can't help with that one.
    Edit - you are running your filter for 4 hours or just the SWG?
    30,419
    Temple,
    Your CYA should be 60-80ppm with an SWG.
    The presence of CC's in your test results indicate the need to shock your pool. Before adding additional CYA, bring your FC (with bleach) up to 15ppm and HOLD IT THERE UNTIL......
    A. You hold FC loss to 1.0 or less overnite
    B. Your CC's test .5 or less
    C. Your water is sparkling
    Then, increase your CYA per the recommended level and run your FC around 3-5ppm
    May 2008
    California City, CA
    51
    I just did some research online and read that because my phosphates are so high, it will bind up my free chlorine. Does anyone know of a phosphate eliminator??
    May 2008
    California City, CA
    51
    After doing more research, it looks like there are some liquid phosphate eliminators and there is also a mineral sanitizer that hooks up to the pool plumbing and has a cartridge that eliminates the phosphates. Anybody know anything about either of these?
    30,419
    temple,
    I am suggesting you disregard phosphates and shock your pool. Phosphates are very unlikely to be your issue.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    FYI - even at 100% output on your swg, a run time of only 4 hours on may not be not enough to maintain your FC which is probably why it got so low in the first place.
    After you are done shocking, try running your swg for 8 hours after dark at 100% and then adjust the output or runtime to maintain your FC.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Guest
    get your CYA up to about 70-80 ppm, shock the pool with bleach to about 20 ppm and then see if you FC starts holding.. I have a feeling it will and you won't be needing to run your SWG at 100%. BTW which SWG do you have?
    SeanB's Avatar
    Mar 2007
    2,622
    Quote Originally Posted by waterbear
    I agree it shouldn't take 100% unless it's undersized for the pool, which is unlikely at 16,000 gallons. I think it would be better to add too much for a couple days after shocking while he adjusts the run time and output than to have too little. Cutting back is much easier than having to shock again and 4 hours a day at 100% doesn't seem to have been doing the job.
    TFP Founder
    May 2008
    California City, CA
    51
    I added a ton of bleach to the pool last night to bring the FC level up and this morning I wake up and the pool is green. That's not from algae, it means the stain is coming back again. That's what always happens when I add a bunch of chlorine. My chlorinator is a Jandy AquaPure 1400. It's plenty big enough to chlorinate our pool. I still think I'm missing something.
    11,969
    This was that other thread about phosphates this week.
    Did you read this?
    http://www.troublefreepool.com/viewtopi ... phosphates
    "The stain is coming back again" ??? is this a different thread? I'm missing something do you have metals?
    11,969
    Okay, I read your other posts....yes, I was missing a bit of info.
    On a related note, your earlier post about mineral sanitizers - DON'T you will be adding metals to your pool and it won't help anyway.
    On the ealier threads about stains, you were advised about metal sequesterants. Have you dosed your pool recently, with 'metal free' or something similar? You obvisouly have followed all the advise about lowering ph etc., and you are trying to shock to drop the CC's but I didn't see anywhere if you added the sequesterants?
    Did Leslies test for Iron or Copper? Or just Phosphates?
    May 2008
    California City, CA
    51
    That was a different thread poolmom, I'm sorry. This all started when I treated my fiberglass pool with ascorbic acid to get rid of the stain. I had to bring my chlorine levels down to 0 and can't get them back up. The pool store test says I don't show a big metal problem, but I still treat with a sequestrant a couple times a week. The pool stain always comes back as soon as I treat with a bunch of bleach. Thanks for the thread on phosphates. Because I have a fiberglass pool, I never really have algae. Up until this morning, my pool looked awesome, it was just that the FC level was low.
    11,969
    Wow, okay I'm stumped. Perhaps the phosphates thread will give you some leads....
    30,419
    If your pool turns green and it's not algae, you most likely have metal content in your water.
    If you mentioned that you've already had this experience, I think we all missed it.
    May 2008
    California City, CA
    51
    After I add my ascorbic acid I also add metal free and add it as well 1 - 2 x a week. But the stain only stays gone for a month at a time. Then I spend a bunch of time getting the chlorine level up, only to drop it down to add the acid. It's a never ending cycle and it's killing me!
    11,969
    Quote Originally Posted by templehb
    Can you post the numbers for the metals from the pool store test?
    11,969
    I hear ya. Do you have ANY hair left?
    May 2008
    California City, CA
    51
    Stupid pool store was out of the metal test stuff. Figures, huh? But in the past they said that metals were low in the test.
  20. Back To Top    #20
    11,969
    My copper level was low on the pool store test last year. My dog's white hair still turned a pale green....my blonde son's hair turned green....
    A pool store employee once told me "not to worry about that" when I asked about a CYA test and why they didn't perform it.
