Thread: Pump's gone out - best way to keep water clear?
    Jul 2011
    Indianapolis
    63
    This is the definition of "extenuating circumstances".
    My pump blew up last night, and I'm 4,000 miles away in England. It is very warm in Indianapolis and there must be a run on pool emergencies, because the soonest anyone can get out is Saturday to replace the pump. Obviously, I'd gladly go grab one and install it myself if I were there, but I'm not.
    Is there any solid, easy-to-understand-by-a-novice method to add liquid chlorine in the interim to keep the pool clear, or (I know I'm pushing it) even swimmable?
    I hesitate to think about pouring and stirring, but would that work? Could I use my pool cover pump (Rule 1800) to assist in any way? Or am I doomed to have to fight a mess in a few days when I get home?
    19000 gallon IG installed in 2003, owned by me since 2010, vinyl liner, 18x36, Sta-Rite PLM-150 cartridge filter, 1hp AOSmith motor on <brand unknown> pump, automatic cover, BBB since August 2011
    22,542
    Re: Pump's gone out - best way to keep water clear?
    Pouring and stirring works as does using the cover pump to circulate the water. I'd have them use the cover pump and stir as well to make sure it's mixed well.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    swimming also makes a great stirring option, that is if they have some way to test FC and are not just blindly pouring.
    Ike
    May 2013
    North East Ohio
    959
    I've used a "sump pump" to keep things moving for 2 months before pumps and worked perfectly!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
