Thread: Mini Max Plus Heater
    Jul 2013
    Canyon Country, CA
    1
    Is there a way to find out the date of manufacture for this heater? I've looked on-line for info but can not find anything. The M/N-400 and the S/N is 00299579. Thanks.
    Pool Gallons: tbd, Spa Gallons: tbd, IG, Mini Pebble, DE Filter, Jandy 2hp vs pump, Pool Construction Completed - June 2014, Chlorine, Jandy PDA Automation.
    Jun 2012
    western NY
    1,560
    Re: Mini Max Plus Heater
    Quote Originally Posted by regan661
    Usually the date is coded in the SN. A quick email to the manufacturer will probably yield the info you need
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
