Thread: Losing water at filter
    Jun 2013
    Orange County, NY
    51
    This is the second time in a few weeks that this has happened. Woke up this morning and noticed the pool water level went down at least 1 inch overnight. This was significant since the water level was already very low, at the minimum level for the skimmer to properly function. I also have a bottom drain in the deep end and had the pump running overnight, 1/2 skimmer and 1/2 bottom drain.
    Went over to the pump/filter and notice a slow trickle of water coming out of the backwash/waste hose (blue hose in picture). Turned the pump off and spun the filter valve around to re-seat it in the "filter" position. Turned the pump on and water going even more quickly into the backwash hose! Turned off again, re-seated the valve handle on "filter" again, turned back on. Now no water is coming out of the backwash/waste hose and all is OK. Filling pool with water from garden hose right now to get level back up to normal.
    Here is a pick of the setup. Do you think it is a bad valve on top of the filter?
    Uploaded with ImageShack.us
    - Max
    __________________________________
    20k gal, inground vinyl, 1 1/2 HP Hayward SuperPump, HW Veriflow XL Sand Filter, Hayward Aqua Rite T-Cell-9, AquaComfort Heat Pump ACT-1100
    Hayward TigerShark robotic cleaner
    Dec 2009
    Central Massachusetts
    2,690
    Re: Losing water at filter
    Most likely a bad spider gasket. You probably just need to get a new one and replace it.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    What he said ^^^
    There are even how-to videos on you tube.
    Jun 2013
    Orange County, NY
    51
    Got it. Did it. Done.
    Thanks!
    - Max
