Results 1 to 7 of 7
Thread: Does anyone use the new bleach tablets?
    cliffstone's Avatar
    Sep 2009
    Killen, AL
    15
    I just noticed these last night when I was buying some 8.25% at Wal-Mart.
    The bottle said it would make the equivalent of 182 oz of liquid bleach (assuming
    that's 6%). It was $2.97 vs the $2.98 for the 128 oz of 8.25%. This seems
    like the way to go if it really does equal 182 of 6%. Less product to handle,
    store and best of all you can dump them in the skimmer basket and they will
    work just like the larger tablets minus the added CYA! Thoughts?
    http://www.amazon.com/Evolve-Original-C ... B008UTREHK
    18x36 IG, 22k Gal, Vinyl, 1HP Hayward SuperPump, 250lb Hayward Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Does anyone use the new bleach tablets?
    The MSDS says it's dichlor. So they do add CYA.
    cliffstone's Avatar
    Sep 2009
    Killen, AL
    15
    Thanks, I knew it was too good to be true.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I'm no chemist, but it looks like the 2 I found online have CYA in them.
    EVOLVE BLEACH TABLETS
    sodium dichloroisocyanurate dihydrate: 25%-100% by weight
    citric acid monohydrate: 1%-10%
    sodium carbonate: 1%-10%
    CLEARON
    sodium dichloroiso cyanurate dihydrate: 99%-100% by weight
    sodium chloride: 0%-1%
    Maybe Chem Geek will be around soon to give us his assessment.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Mar 2007
    San Rafael, CA USA
    12,082
    Richard has the correct MSDS link for this. It's Dichlor so for every 10 ppm FC, it also increases CYA by 9 ppm.
    cliffstone's Avatar
    Sep 2009
    Killen, AL
    15
    It can still be used as a cheaper way to raise CYA. For my pool using it for about 3 days
    would raise the they CYA around 10 ppm.
    I would not use that in a pool. It's made for laundry. Are you sure that there are no problem ingredients?
    How much actual dichlor are you getting by weight and how much does it cost? Citric acid is a reducing agent.
    Support the site
