Results 1 to 8 of 8
Thread: Is this dead algae? Pictures
    First my numbers for my 24 foot round AG pool
    This morning:
    FC 13
    CC .5
    TC 13.5
    PH 7.3
    CYA 30
    TA 100
    CAL 400
    Waited too long and let too much junk get into the pool this spring.. Raised CL level to near 20. Shoveled (with the net) loads of junk out of the bottom of the dark green pool.. kept CL at 20 for about 6 days as I scrubbed and vacuumed to waste. Pump running around the clock.
    Got water to cloudy, milky white color.. but couldn't see the bottom. Added Polyquat (60%) and some clarifier. Also.. I am using a skimmer sock.
    Then Monday morning the water was pretty clear (I could see the bottom).. but I had a bunch of stuff floating on the top.. and a pile of the same stuff in the middle on the bottom. The floating junk looked like this:
    Is this dead algae?
    I was able to carefully scoop out (with the net) the floating stuff.. and I got in and vacuumed to waste the stuff from the bottom.
    Today the water seems a little clearer.. and the floaties are almost non existant.. but I have another pile of the junk in the middle.. looks like this:
    I will vacuum again.. am I still killing algae.. or is this just stuff that settles? Should I stay at a high CL level? I have already spent over $100 in bleach.
    Thanks for your opinions.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Is this dead algae? Pictures
    It sure looks like dead algae. It could be pollen, too.
    Butterfly's Avatar
    South Carolina
    10,045
    You need to pass the three tests that declare when you are done with the SLAM process. See red lines in my sig.
    You're done SLAMing when:
    Quote Originally Posted by Butterfly
    thanks guys... passed the test!
    Update.. as of now (other post was actually yesterdays numbers, etc). Vacuumed to waste again last night. unbolted wedding cake steps and turned them over. Bunch more of that "stuff" came out.. Vacuumed that and netted out some floating "stuff". Water is CLEAR.. just a little (very little) pile of debris in the middle this morning... nothing solid, just loose debris.
    Always like to follow up.. after a "clear up".. just to reassure folks that it really works. A couple of weeks ago it was green and smelled bad.. really.
    this passed weekend:
    Butterfly's Avatar
    South Carolina
    10,045
    Looks great
    Jun 2013
    East TN
    309
    Quote Originally Posted by chuck9997
    I have some steps like that. I just took mine out and cleaned them the other day. On the underside, back in the nooks and crannies there was some algae. Wouldnt have known it from the chlorine demand. There really isnt enough water flow through the steps I dont believe. Also if you have some underwater lights, you may want to remove the cover/bulb and check there.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    I am also in east Tennessee.. near Knoxville.
