Results 1 to 12 of 12
Thread: Help me TURN ON MY LIGHTS !?
    Can seem to turn on my pool lights or spa lights I can even
    Find the switch ??
    38,441
    Re: Help me TURN ON MY LIGHTS !?
    Well how on earth can we help you find a switch?
    Can you find the deck box that should be near the light outside of the pool?
    Theres no box no switch anywhere in backyard on the wall or anywhere ? Im not kidding I have looked everywhere , the circuit is good but cant find a switch
    Heres my yard and pool where would the Light switch be ?
    Anyone got advice ?
    22,553
    Those two devices you point out are X-10 switches. you push them to turn them on and off. They're not reset buttons.
    If you had an X-10 controller you could turn the lights on and off remotely.
    Ok so they should still work if I manually press them ? THey don't do that
    Must mean both spa and pool lights are in need of replacement ?
    38,441
    Or check to make sure your are getting voltage to the switch and after the switch ... if so, then the lights might be bad.
    22,553
    Maybe not. It could be the switches.
    Try pressing them and holding the buttons in a few seconds. I can't see the model of the switches but they may be dimmers and set to zero %.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    If this whole time you were supposed to be looking for a remote....it's going to be good for a laugh!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    it is a X10 device ...Wall Dimmer Switch - Receiver PLW01 ``` the halogen 500 watt bulb was shattered also
    22,553
    Looks like replacement time!
