Thread: reset button ComPool to Easytouch Upgrade
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    Have ComPool to Easytouch Upgrade and two questions please
    1) if I have 3 pump times (12-2, 8-10, 4-6) and change them to (12-3, 8-11, 4-7) do I have to hit the Reset button to activate the new schedule?
    2) What does the Reset button do? (manual is very vague)
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    22,550
    Re: reset button ComPool to Easytouch Upgrade
    You're right, the manual is pretty vague on it. All it says is that it "ReInitializes the outdoor panel". It appears that it re-establishes communication with the panel. You may want to call Pentair and see if they'll explain it to you. If they do it would be nice if you'd post what they say so we'll know in the future.
    Jul 2012
    Whidbey Island, WA
    397
    here is what they said
    The RESET button at the outdoor panel will do a soft reboot to the system. All of your circuits will turn off momentarily and then the system will continue to run the scheduled programming. It is not necessary to push the RESET button to activate the new schedules.
    thank you
    22,550
    Thanks for posting that. It would have been nice if the manual had just said that.
