Results 1 to 7 of 7
Thread: I found this on Pinterest.
    May 2013
    Tx
    12
    http://pinterest.com/pin/55591376623409152/
    I think a smaller version of this will be my next venture. I've been looking something to make it easier for larger older people to get in and out of the pool...
    Copied instructions:
    "The Decking
    The planking is a product from Home Depot advertised on the shelf as "Garage Door Trim".
    It comes in 8 or 10 foot lengths and is 5 1/2 inches wide by 3/4 thick.
    It is very light (the 10 footer comes in around 2-3 pounds)
    It has 1/4 inch deep ridges on the underside. The top surface has a wood grain effect which in my opinion provides a decent non slip surface.
    It looks as though it is designed to be painted over, since who would want a bright white wood finish.
    The cost is about $16 for the 10'. I used nine of the 10s and one 8 footer.
    Just over half of the total cost came from the planking.
    I secured them to the 1 1/4 PVC tube with 3" countersunk galvanized machine screws/lock nuts.
    About $26 for a box of 100 and I used 98.
    If I can find a good online source, I will replace with stainless next year.
    (no sign of corrosion yet after 6 weeks submerged)
    The Frame/Structure
    1 1/4 pvc sched 40 tubing. I used 10 10 footers.
    I bought all of the unions online since I needed 4 and 5 ways which HD did not sell.
    They are furniture grade PVC connectors which I was happy to use since they have smoothed/beveled edges. The sched 40 ones were a bit rough.
    They cannot be used for plumbing.
    I used a combination of approx 30 T / 3 / 4 and 5 ways at about $2 a piece incl shipping from US Plastics http://www.usplastic.com/catalog/def...arentcatid=690
    Regular PVC cement.
    The planking is not as sturdy as I originally looked for, so I had to reduce the span width between tube supports to 24 inches.
    I would recommend 16" inch since my family are somewhat light weights.
    Assembly
    The whole thing took about 5-6 hours to build (maybe less if you are more used to working with PVC plumbing tube/unions).
    Note from experience: work from one corner to the opposite.
    Think about how the next 2 to 4 unions will go together and will the frame bend in that location to accommodate 2 joints at once.
    I tried to connect 3 pipe ends to one union at the same time but it was not easy and I would recommend thinking ahead and trying to avoid.
    Clean up the unions as you do each one since once the glue is dry it is much harder to remove and causes imperfections at the joints.
    Very Important: Remember to drill about 1/2 inch holes at all corners if you want it to be sunk.
    Tools
    Chop Saw
    Drill/Screw driver/Countersink
    Wrench
    Installation
    The whole thing weighed about 120 lbs.
    Easy for 2 to carry to the pool but it took 4 people to lift over the edge.
    At first it made a nice floating island. The PVC tubes and unions and hence frame would sink with no problems. But the planking is very buoyant.
    Once I stood in the middle of it, it became apparent that at least 100 lbs was needed to sink it (once all of the bubbles came out of the frame) I went for rocks but will be rethinking this next year.
    Hard plumbed 4 year old 20x48 Ultra Frame
    Thru-wall skimmer
    Hayward Matrix sp5610 pump. Hayward 19" filter.
    Jul 2007
    SW Indiana
    10
    Re: I found this on Pinterest.
    Very cool!
    21'x 52" round Vogue pool, 1 1/2 HP Sta-Rite pump, Crystal-Flo sand filter & Polaris Turbo Turtle
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I'd make sure no one can become trapped under it and that there is good water flow under it to prevent algae.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2007
    Hillsborough, NC
    525
    Just FYI, I have worked with that PVC trim. It is trim and should not be considered structural. I would not use it for planking - I can snap it without too much trouble barehanded. I would use composite decking instead.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    May 2013
    Tx
    12
    Quote Originally Posted by msgtdan
    I'm not going to use the "shallow end" idea just the exit steps. I've been looking for a economical way to build a set of steps. After reading posts and searching on the internet, I've come to the conclusion that I may be better off building my own pool entrance/exit system rather than buy something that I'm not going to be satisfied with or perform up to my expectations nor up to the manufacturers claims. Thanks for the heads-up on safety.
    Quote Originally Posted by crokett
    I went to HD today and looked at it and it says vinyl garage door trim. I don't know if pvc and vinly are of the same material BUT composite decking is an excellent idea. I just checked out Lowes.com and seen where it CAN be used under water. THANKS!!!
    Thru-wall skimmer
    Oct 2012
    Houston, TX
    186
    scary. no way.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    May 2013
    Deep East Texas
    79
    I like it.
    In ground 25,000 gallon - vinyl liner - Sand filter - residential pool
    Also maintain two commercial 190,000 gallon competitive indoor bromine facilities -9x Sand filters
