Results 1 to 11 of 11
Thread: 2" to 3/4"
    JFB's Avatar
    May 2013
    Monréal, Québec, Canada
    96
    2" to 3/4"
    I have 2 inch plumbing. Everywhere. I am installing 4x pentair deck jets II that each have a 3/4 inch pipe fitting. My plan is to build a 2 inch plumbing loop with 4x "T"s coming off of it. Each of the Ts will be followed by a 3/4 inch valve to control flow to each jet.
    Problem. I can't seem to find Ts that reduce 2 inches into 3/4 inch. I know I can buy reducers, but I'd have to buy lots of them, ie 2 inch to 1.5 inch to 1 inch to 3/4 inch. Times 4!!!
    Am I thinking about this correctly? Is there an easier way to build this?
    Thanks for the advice.
    JF
    13.5k gallons, IG, Vinyl, Hayward C3030 Cartridge, Hayward Tristar 3/4hp single speed, Hayward T-15 SWG, Hayward P4 automation, 234 sqft Solex Solar panels. April 2013 construction, Dolphin DX4 robot, TF-100 test kit, Pentair Deck Jets 2.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: 2" to 3/4"
    Where are you trying to find the fittings?
    Plumbing specialty stores will have a better selection closer to what you need.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: 2" to 3/4"
    Quote Originally Posted by JFB
    There are Tees that the side leg is a smaller diameter. This one is even threaded, so you just screw in a reducer bushing and go.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: 2" to 3/4"
    1.5 inch T's with 3/4 stubs are common, so you might consider doing a stub reduced to 1.5 inch with a series of 1.5 inch / 3/4 inch T's
    38,284
    Re: 2" to 3/4"
    I had no problem getting a 2" to 3/4" threaded reducer at Lowe's or home depot. One part, less than a buck. Glue right into the tee fitting.
    JFB's Avatar
    May 2013
    96
    Re: 2" to 3/4"
    My Rona (kinda Home Depot) and Home Depot do not carry these... Nor do any of my pool stores. I feel like a freak when I ask. They look at me and say "what the **** you tryin' to do?" Like I am from Mars or something. I feel like I'm the only one in my area to ever put in some deck jets! If anyone finds a US site that offers these PVC fittings, or has a better idea on how to proceed with this idea of mine, please post link!
    Thanks.
    JF
    JF
    Richard320's Avatar
    Jan 2010
    18,995
    Re: 2" to 3/4"
    Thanks.
    JF
    https://www.acklandsgrainger.com/AGI..._code=WWG5WNZ0
    JFB's Avatar
    May 2013
    96
    Re: 2" to 3/4"
    :P
    Richard. As always, you are too much help. I don't really need this forum... I just need access to you 24/7 !!!
    Thanks a million. I will order ASAP!
    JF
    JF
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: 2" to 3/4"
    I have found there are something's that Lowes carry that HD doesn't. I find I need to go to Lowes when I can't find it at HD. I had this same issue with a specific type of irrigation pipe.
    -- Guy --
    May 2013
    NJ
    114
    Re: 2" to 3/4"
    My local Lowes stocks these for less than $2 each (2x2x3/4). The 3/4 part comes in threaded or slip. They also carry a 2" to 3/4" bushing, threaded or slip. http://www.lowes.com/pd_317748-1815-401 ... facetInfo=
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
    Apr 2013
    NJ
    57
    Re: 2" to 3/4"
    Cant help with the fittings and pipe, but I am interested in your install of the pentair deck jets as I am planning the same can you please keep us updated on your install with some photos....Thanks.
    24,000 gallon vinyl, 2 main drains, 2 skimmers, 4 returns, 2 inch pipe suction, 1.5 inch return. Pentair VS pump, Pentair IC-40 SWG, Pentair SD-80 filter. TF-100.
