Results 1 to 9 of 9
Thread: green rim on pool step and liner
    Hi everyone,
    We are having a very hot start to summer in Ontario and I now have a green rim around the pool.
    Any ideas on what it is an how I can remove it and or treat the water?
    T
    13,000 Gal (Est.) 14x28 pool w liner
    Hayward salt system - Aqua rite low salt
    Hayward Pro Series Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: green rim on pool step and liner
    Welcome to TFP. See the section on Slamming your pool in pool school.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Bleach, brush, and elbow grease. Your SWG won't be able to generate enough FC to get ahead of the demand once an algae bloom starts. You'll be needing bleach. Here's the article on how to SLAM it. You will have trouble getting your hands on a proper test kit in Canada. Apollo Piscines has the monopoly up there.
    I have a super chlorinate setting on my salt system - should I super chlorinate and see what happens?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I wouldn't use the SWG. No sense in it. They usually cant keep up with the FC demand. Bleach is the way to go.
    Jeff
    Apr 2010
    East Texas
    9,643
    finally-got-it-t66366.html
    This member says he may be able to help you procure a test kit.
    what bleach should I be using? Regular clothing bleach?
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by trevsand
    Yep. Avoid any of it with special features like "outdoor," or scented, or splashless. Lust plain bleach. Read the label - if they won't tell you the strength, avoid it. You're just paying for a lot of extra water.
    Butterfly's Avatar
    South Carolina
    10,045
    Yes, plain, unscented household bleach. Check the % on the label. You can also use liquid chlorine (same as bleach, just higher %/stronger) usually found at pool stores, big box stores, etc.
    Have you found the PoolCalculator.com yet?
    You can use your SWG to help maintain shock level if you want, but be sure to turn it off when doing the OCLT.
    Also, we recommend that you do not run your SWG at superchlorinate mode as it will shorten the life of the cell (and the SWG is not capable of reaching shock levels).
    You're done SLAMing when:
