Thread: New to TFP, fairly new pool owner
    I was out of town and chlorine level got too low and when I open the pool the water was cloudy. I began the shocking process per the forum and was wondering how long this process can take. My water is now crystal clear, but I can't seem to maintain chlorine level overnight (drops more than 1 ppm). My pool metrics are:
    FC = 20 (shocking and have been shocking for four days)
    CC = 0.5
    pH = 7.5
    CYA = 50
    Alkalinity = 140
    Typically, the FC level drops to 12 to 15 ppm overnight, so I assume I am still fighting the algae. How long can this process take? Days? Weeks?
    Also, I was curious how much I can expect the FC to drop on a typical day with pool temp 85F, sunny skies, and multiple people in the pool for 8 hrs.
    I appreciate any input
    38,262
    Re: New to TFP, fairly new pool owner
    Welcome to TFP!!!
    The SLAM process takes as long as it takes ... anywhere from a few days to a few weeks.
    A clean pool with no use will lose 2-3ppm of FC to the sun each day ... having people in it will raise that number at least a few ppm ... how clean are the swimmers and do they visit the bathroom?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It can take days. Your done when
    1 you pass the OCLT
    2 CC OF 0.5 or less
    3 water is crystal clear
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    You're dropping 5 to 7 points overnight............. I sure don't understand how your water is described as crystal clear. And if so.........you are NOT maintaining ad adequate SLAM level. You need to check it more often it seems so that it does not drop below SLAM level overnight.
    Ok, thanks for input and will measure more frequently and continue to SLAM. What FC level is too high to swim in?
    38,262
    We say it is safe below shock level, assuming the water is clear.
