Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: NO FC-pool store said phosphates present
    Hi everyone! I do not have a proper test kit yet. Have only had water in my new pool since Thursday 7/11/13. I let my filter run 24 hrs before I turned on the SWG. When I did the dip stick test I had no FC on Saturday 7/13/13. I took a sample to the pool store:
    TDS- 500
    CYA- 10
    Tot chl-0
    FC-0
    pH-7.3
    Tot alk-60
    Adj total alk-57
    Total hardness-40
    Salt-2975
    I added
    5.5 lbs alk increaser
    .25 lbs pH increaser
    5.5 lbs chl stabilizer
    19.5 lbs cal hardness increaser
    I ran SWG twice 8 hours each time and Sunday morning 7/14/13 did another dip stick test and all levels were perfect.
    I did another dip stick test this morning Tuesday 7/16/13 and no FC! Took sample to pool store and this is the results:
    CYA-30
    Total chl-0.1
    FC-0.1
    pH-7.5
    Tot alk-80
    Adj total alk-71
    Tot hardness-170
    Salt- 3094
    Then they did a phosphates test I assume because all other levels are good. They sold me phos free, I'm just not sure whether or not to add it. They said I have to put it in the basket on the filter because I don't have a thru wall skimmer. But put in 1/4 of the bottle, run filter for 24 hrs, put another 1/4 bottle in and run for another 24 hours and then put in 2 lbs of shock. Is this the right procedure for my intex pool and filter? I need the pool to be ready for my nephews bday pool party that I have already postponed once. Am I going to have to postpone it again?
    Thank you for any advice,
    Barb
    ~Barb~
    40,000 gallon ig. Custom shape gunite, sylvan pool. Pool guy guesstimates 40,000-45,000 gallons. Hayward pump. Just moved here, that's all I know.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: NO FC-pool store said phosphates present
    You've been pool-stored.
    Your vinyl pool doesn't need calcium. But the store needed the sale. Ka-ching.
    Phosphates are not a problem if you maintain FC. Ka-ching.
    I haven't got a clue what my phosphate reading is, if that tells you anything. Use the search box for phosphates and get edumacated.
    You DO need to get the FC level up. NOW. Bleach is the fastest. Essentially, all it will add is a little bit of salt and the chlorine. We recommend getting the pool balanced and adjusted well as a bleach pool before adding salt or turning on the SWG. Then it's a seamless transition.
    38,237
    Test strips are worthless.
    Pool Store testing is worthless.
    Phosphate remover is worthless.
    You need a Recommended Test Kit. And you need to be using bleach to maintain the FC levels. The problem is that your CYA level is too low and the SWG is not able to produce FC faster than the sun is destroying it.
    Order a kit.
    Use bleach to supplement the SWG
    Verify the CYA and raise it.
    Then dial in the SWG output.
    Thank you, I was really hoping you'd say that! But I wasn't sure that I should with all the **** they had me add. I will search the site for the quantity of bleach to add, unless you can kindly tell me, there is 14,360 gallons of water in my pool.
    ~Barb~
    38,237
    Use poolcalulator.com ... with a CYA of 30ppm ... you have to use enough bleach to keep the FC > 2ppm at all times: pool-school/chlorine_cya_chart_shock
    Thank you!
    ~Barb~
    I added the bleach but couldn't find 6% I used 64oz of Clorox concentrated with 8.25%. According to dipstick, yesterday morning everything was good. I know they are no good but it's all I had. I just got my test kit yesterday late afternoon, I have not had a chance to use it. I will post results when I do. Does anyone run their SWG at night? It suggests to run it when it's less humid like 10am. If I run it then, we can't use the pool! I currently have the filter running at 11pm for 12 hrs and the SWG for 10 hrs. Now if I could just find a way to vacuum it!!!
    ~Barb~
    30,402
    ???? Running your SWG while using the pool is fine.
    The manual suggests not running filter and SWG when pool is in use. SWG manual page 3-"Do not operate this product when the pool is occupied." ??? Which I thought was a contradiction when they suggest running at 10am, I can't find it in the manual now.
    ~Barb~
    Isaac-1's Avatar
    SW Louisiana
    6,711
    From what I understand many Intex pool pumps are not UL listed for pool use, so they say not to run them while pool is occupied due to potential risk of electrical shock.
    Ok, I put 64oz of bleach in, my test kit came, TF-100. I think everything is good. Here are my stats as of today:
    TC 3.5 FC 3 CC 0.5
    TA 90
    CYA 30
    Br 6
    Ph 7.4
    Salt 6.4.
    If I am reading this correctly everything is on the low end of good. Would that be correct? I'm not sure how to put this info into the calculator. I have an SWG, but had to add bleach due to no FC, so should I compare to the bleach or SWG goals?
    NO MORE POOL STORE FOR ME! Thanks to TFP!
    ~Barb~
    38,237
    Are you intending to use the SWG? If so, you should use those numbers.
    All I see is that your FC is on the low end for your CYA of 30ppm using the bleach numbers (since the SWG is not keeping up). When you are ready to get the SWG going, you will need to raise the CYA.
    You do not have bromine, so no reason to post that.
    What does the water look like?
    I would suggest raising the FC up to about 10ppm and doing the OCLT to confirm there is nothing in the water. If you pass, then raise the CYA and get the SWG running.
    Yes, I have been using it since day 1, but because it couldn't keep up with FC I added the bleach. The SWG runs 10 hrs a day. Water is and has been clear since day one, but have not been able to vacuum, yet, on its way.
    ~Barb~
    38,237
    Well, turn it off, boost the FC for the OCLT, and find out if all you need to do is raise the CYA to help the SWG, or if you need to SLAM the pool.
    I'm sorry what is OCLT? (Ill go see if I can find it)
    ~Barb~
    38,237
    Found it, I do not have FAS-DPD, unless its something within my TF-100 kit. I will go look at the store.
    ~Barb~
    Yes it is in my kit. Thanks Jason!
    ~Barb~
    38,237
    The whole point of buying the TF-100 was to get the FAS-DPD test ... it is the FC and CC test that uses the powder and you count the drops.
  20. Back To Top    #20
    Please be patient with me, this is my first pool, ever. I am a hands on learner. Thank goodness for this site and for those of you who help those of us who know nothing.
    SWG is off sun is almost down.
    ~Barb~
