Results 1 to 8 of 8
Thread: Hayward Ultra max 2 Pump programing
    Looking for a suggestion. I have a 1.5hp Ultra max 2 pump and according to the information on their site, as well as the manual, I should be able to program the run time. I've tried as explained in the manual but I always get a long beep when I switch the toggle to program. I never get the individual beeps as the manual said I should. The pump runs continuously until manual switched off. Any suggestions or thoughts?
    22,550
    Re: Hayward Ultra max 2 Pump programing
    I found this that may help.
    TO SET TIMER
    1. Move switch from OFF to PROGRAM then back to OFF - resulting single tone indicates Setting #1. Repeat until number of tones heard equals setting desired. ie 3 rapid tones is Setting #3
    2. Move switch from OFF to RUN: to begin selected program setting.
    SINGLE SPEED MOTOR SETTINGS
    Setting 1 - Pump runs 24 hours Continuous (single tone)
    Setting 2 - Pump runs 18 hours, off 6 hours (2 tones)
    Setting 3 - Pump runs 12 hours, off 12 hours (3 tones)
    Setting 4 - Pump runs 6 hours, off 18 hours (4 tones)
    TWO SPEED MOTOR SETTINGS
    Setting 1 - Pump runs 24 hours on Hi Speed (single tone)
    Setting 2 - Pump runs 18 hours on Hi, 6 hours on Low (2 tones)
    Setting 3 - Pump runs 12 hours on Hi, 12 hours on Low (3 tones )
    Setting 4 - Pump runs 6 hours on Hi, 18 hours on Low (4 tones)
    TO OVERRIDE TIMER SETTINGS
    Move switch from RUN to OFF and back to RUN within 3 seconds. The pump will run for 1 hour and then return to the previous programmed setting. If a power failure occurs the timer automatically returns to the programmed setting.
    Are these the instructions you're following?
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Yes I followed those instructions but I only get a continuous beep. Stumped!
    22,550
    I can't find the manual for it. Does it have anything in the troubleshooting section about it?
    I don't have the original book. I looked it up on their site and found a scanned copy. Nothing explains the issue I'm having. Might have to buy a timer and go that route.
    22,550
    Have you tried calling their tech support? They might have an answer.
    I will be seeing as it looks like i'm stumped. Thanks for your help.
    22,550
    Please post back what they have to say.
