Thread: Diver Dan / AquaBug question
    Jul 2010
    Raleigh, NC
    60
    I have a 26' Intex with standard 1.5" fittings + standard Hayward 2speed 1HP pump + sand filter. I'm pretty sure this type of vacuum will hook right up but .....
    Should I be concerned that this "suction" type cleaner will tear the liner?
    Trying to find an affordable auto vac option for the pool but don't want my laziness to cause a leak and/or bigger issue down the road !
    26' x 52" Intex Ultra Frame (14,667 gallons), Hayward Matrix 1hp 2speed, Hayward ProSeries 21" sand filter
    1.5" PVC piping with in-wall skimmer, TF100 test kit
    City water in Raleigh, NC
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Diver Dan / AquaBug question
    You should have no trouble installing an Aqua Bug with the fittings included in the box.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I have had two aquabugs (still have my old one) and they work great. I have never had it stick to the floor but I had stuck to toys.
    You can see my old one here. You can see the base at about the 2:28 mark IIRC. You can also hear my wife ask "Why?"
    [youtube:21ax63oj]NJrIqkf9k9A[/youtube:21ax63oj]
    -- Guy --
    Jul 2010
    Raleigh, NC
    60
    Ok - thanks
    Does the cleaner have a timer or do I have to turn it on / off manually?
    Jun 2012
    Howell, NJ
    977
    You have to put it in and hook it up manually. Once it is done cleaning, you have to manually remove it from the pool.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    When I need to clean, I hook it up to the skimmer and get all the air out of the vacuum hose and such and then I let him stay attached until i get home from work. The timer that controls my pump/filter will have him clean for about 3 hours and all will be done when I get home from work. When he is connected, the skimmer is not active so your surface can get more debris on it. I can then take him and the hoses out of the pool.
    -- Guy --
