Thread: NEW to BBB method this year Sanity check
    Jul 2012
    Marietta, GA
    2
    I am a second year pool owner and decided to give the BBB method a try here are my numbers, I think I am good but wanted a second opinion
    Pool is 40,000 gal plaster
    FC 6.5
    PH 7.4 (I have to add 1/2-1 gallon of acid per week to keep this down below 8)
    TA 60
    CH 250
    CYA 65
    Water is clear
    Any comments are appreciated
    Thanks
    40,000 Gal IG Plaster
    Sand Filter
    38,246
    Re: NEW to BBB method this year Sanity check
    Welcome to TFP!!!
    Please add your pool details to your signature and location to your profile as described HERE as it will help us help you.
    Besides the CYA being a little on the high side for a non-SWG pool. Looks good to me. You just need to make sure you keep the FC > 5ppm at all times.
    Do you have a lot of aeration that is causing the pH to climb? Or is it new plaster? With the lower TA, I would not think your pH would be rising so fast unless there is an outside reason.
    Jul 2012
    Marietta, GA
    2
    Jason
    Thanks for the quick reply, I can run 2 waterfalls but I try to keep them off unless someone is swimming. The pool was SWG when I got it last year but I went away from it after I had constant problems with the cells. I have been working to get the TA & CYA down for 6 months now. The pool is 10 years old
    Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd say you have things under control and you should stop worrying and go swimming.
