Results 1 to 8 of 8
Thread: Swg vs robotic vacuum which would you chose
    May 2011
    Orillia, ontario, canada
    50
    Hello all
    If you had a choice between the 2 which would you choose..?
    I currently have an Alger bloom, and my kreepy isn't doing a good job cleaning the whole pool, mind you it's probably 5 years old.
    Either buy a swg and possibly a new kreepy or only a robot under 1k?
    Keep in mind I'm cheap.. Lol
    Ps I have a vinyl lined pool.
    I also have a 2 speed new pump
    Thanks!
    Approx 74,000 liter inground vinyl pool 12x32, laser 225 sand filter, Hayward 2 speed pump + old pool heater.
    38,248
    Re: Swg vs robotic vacuum which would you chose
    You of course realize that neither of them will fix the algae problem, right? If you were maintaining enough FC, then you could have no cleaner and a dirty pool and algae would not grow.
    Depends what you value most. A SWG would help maintain the FC, so if you have not been consistent with maintaining FC, that might be a better choice to avoid the algae problem ... although realize this does not mean you can neglect the pool.
    BTW, you need to follow the SLAM process first anyway. [slam:3fb40cie][/slam:3fb40cie]
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Jbliz beat me...
    The Kreepy isn't going to be very useful while fighting algae. Brushing will help much more. I would focus on getting rid of the algae before considering the other stuff, neither of which will help with your current problem.
    May 2011
    50
    BTW, you need to follow the SLAM process first anyway. [slam:3evl2axw][/slam:3evl2axw]
    Yeah I know they won't cure all problems... But limit them..
    Well I'm not 100 % sure I'm in an Alger bloom, I.ve never had FC =0 but 1
    I put a whole bunch of soil around the pool and it has been blowing in for 4 weeks .
    When I backwash the sight glass is brown.
    The water has been blue but the temps have been low - 22c .... Since Saturday the temp has been 30+ and it started to be green only when we swim or set the kreepy free in the pool.
    I boosted the bleach last night over 16, and I checked it today and it was down to 8.5. Water was crystal clear but there was a brown \ green coating all over.
    I've been vacuuming the pool every day for the last 4 weeks..
    I will continue the shock process in the mean time.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    If you're losing more than 1ppm FC in an OCLT, you need to SLAM it. It sounds like you're doing just that, but an OCLT will tell you if It's organic, or just dirt.
    What sort of filter do you have? If It's sand and it has been in there more than one season, follow the cleaning instructions in my sig. After that, consider adding DE/cellulose to speed the clearing process. See article on adding DE to a sand filter in PS.
    Also, please fill out your signature as instructed in Pool School on the 1st link. Then fill in at least your location info in the profile section under user control panel @ top.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    May 2011
    50
    I'm doing the oclt tonight.. I think I'm going to try and clean the sand filter once again this year.
    Tx
    38,248
    So you have the FAS-DPD chlorine test that is needed to correctly perform the OCLT?
    If so, why have you not been using to to prevent the algae in the first place?
    There is no point in doing a OCLT is you can see algae in the water. You need to SLAM the pool. [slam:1rroldge][/slam:1rroldge]
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Since they've all gone off on a tangent...
    I'd get a SWG. I don't get very much debris in my pool - the back yard is mostly patio. I can spare the twenty minutes a week it takes to vacuum.
