Thread: HELP! Pool is hot!
    Jun 2008
    Richmond, TX
    14
    HELP! Pool is hot!
    Hello from S. Texas! I have a one-year old pool that is in full sun until about 6:00pm. The water hits 90-94. We like it around 85-88F. Is there anyway to cool this down? I have a waterfall and someone suggested running it all night. Thanks for any suggestions
    20,000 gallon gunite with colored plaster,
    Hayward 60 DE filter, 2.5HP Hayward pump, Hayward Phantom cleaner, Rainbow 320 Chlorinator, Nature 2
    Jun 2008
    Chesapeake, VA
    19
    Hi TexasDude, welcome to TFP!
    Anything that promotes evaporation should help cool off the water, so the waterfall at night should help as well.
    You can always try a fountain too... I got a good cheap 3-tier one off ebay for $20. Plus it looks nifty!
    I've also seen some large sun shades (aka sunsail, shade sail, etc) around the Internet, like Coolaroo or even some fairly inexpensive ones on Overstock.com that could possibly offer some shade over your pool. It would have the added benefit of keeping the sun off you if you swim in the daytime! http://www.overstock.com/Home-Garden/Sq ... oduct.html? (they also have a triangle one.)
    ~12000 gallon 15x30x4 On-ground Pool
    Aqua-trol SWG
    Polaris 65 Pool Cleaner
    Hayward C500 Cartridge Filter (50 sq ft.)
    Working on being troublefree!
    Jul 2007
    Alamo, CA
    187
    If you have a solar heater, you can run it at night to act as a radiator. Of course, if the air doesn't drop below your pool's temp at night, then it's not much help. You could hose down the panels, though, to take advantage of some evaporative cooling that way.
    Other than that, evaporation is your best bet.
    blubluenoiseise
    My pool: 14,750 gallons in-ground plaster
    FAFCO Solar panels (seven 4' x 12') with a Goldline automatic controller
    1/2 HP WhisperFlo filter pump, Kreepy Krauly cleaner, Cartridge Filter
    Aquarite SWG, Satisfied user of the TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Hey TexasDude,
    Another member from Texas Imagine that! Welcome to the forum!
    Here's a link to an ongoing thread for cooling the pool:
    http://www.troublefreepool.com/viewtopi ... ght=cooler
    You're done SLAMing when:
    Aug 2007
    Northeastern Ohio
    178
    If only I had an inexpensive way to swap about 10k gallons with you...
    My water just hit 77 here after a week of 90+ degree days.
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
