Thread: Caretaker 99
    Guest
    Caretaker 99
    Topics merged. Please don't double post. Bama
    I also have a Caretaker Ultraflex 2 system. After running for 3-4 minutes it pops the reset breaker that is on the transformer. I can reset it and the motor appears to spin again for another 2-3 minutes and pops the reset again...any help would be appreciated..thanks
    Guest
    caretaker ultraflex 2
    Hi, I have a Caretaker Ultraflex 2 8 port system. When the system is turned on it will run for 2-3 minutes then it pops the reset button that is on the transformer in the control box. You push the reset then it will continue to run for another 2-3 minutes and pop again. The motor appears to be turning properly until it pops the breaker. It pops it almost to the second each time you reset it.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Caretaker 99
    Welcome to TFP!
    I'll admit I'm not too familiar with the electric valves, but it sounds like perhaps water has gotten somewhere it shouldn't? Hopefully someone else can help...
