Thread: The spa jets aren't spinning
    Spa is about 7 years old. Of the 6 jets, 3 spin freely, but the other 3 don't. They move if I manually spin them, but then they stop right away. Is it possible to replace them? Are they just spun onto the pvc, or are they embedded into the pebbletech and can't be replaced?
    30,000 gal salt with spa; built 2006; Jandy 2 hp single speed Stealth; 48 sf Pentair DE filter; Pentair 4 wheel cleaner; Jandy 1400 SWG and 1400PLC salt cell. New filter grids, cleaner pump.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: The spa jets aren't spinning
    Most spinners can be replaced. Just unscrew them. But it could be a reduction in flow rate that is causing the problem. Have you backwashed the filter recently?
    Mark
    Thanks, Mark. Yes, the filter is clean. When I spin those spinners by hand, they don't go freely. They feel like they've aged or warped or something. Just not an even spin. I may take one off and see if there is anything keeping it from spinning.
