If the popups are not all working, there is something wrong with the innards of the valve. If you take off the retaining ring and pull off the top, you'll be able to see a little impeller that should spin and turn the whole assembly. If it's working right, you can spin that with your hand and watch the whole thing move...take if off and see if you can tell why it's getting stuck! I guarantee you can fix this yourself.
