Thread: Filter Source
    May 2013
    CT
    17
    Filter Source
    I'm looking for a the cheapest supplier
    of pool filters,and how do you figure out
    your replacement filter size?
    15600 AG
    Filter Cartridge
    Waterway HI-FLO 48 2 Speed
    HI-250 GPM,LOW-144 GPM
    BBB,Leslie DPD Tester
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Filter Source
    From the table in Hydraulics101, for your 15600 gallon pool we would recommend as minimums:
    • 2.9 sq.ft. sand filter
      228 sq.ft. cartridge filter
      44 sq.ft. DE filter
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Filter Source
    What does this mean in your signature? There is no way the pump is producing that much flow rate.
    Mark
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Filter Source
    Are you looking for replacement cartridges for your filter, or a new filter?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Filter Source
    Quote Originally Posted by JohnT
    Are you looking fro replacement cartridges for your filter, or a new filter?
    I see I probably have misunderstood the question
