Thread: Just installed thru wall skimmer on our intex ?
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Ok finally got a thru wall skimmer installed and I have a question.
    Should I also install the new return that came with it? Would it help move the water better?
    I was messing around and put the new return on the return that's in the pool now and it seemed to add a little more pressure to the water coming back in the pool. I don't know if that's good or bad.
    Not sure what skimmer I got, I will check the box later.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    22,548
    Re: Just installed thru wall skimmer on our intex ?
    You can stick with the original return or you cna install the new one. Whichever you want. The new one should have an aimable eyeball that might help the circulation a bit.
    Feb 2013
    Yukon, Oklahoma
    220
    If your considering hard plumbing then for sure put the "real" return on it and enjoy the extra flow. You will then be able to chose any type of return noozle you would like or rig up a fountain setup that you could screw into that standard fitting when needed.
    It's not that the Intex return is bad, it's that the standard Hayward return gives you so many more options.
    Bob E.
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    I was going to hard plumb but after watching the pool move from side to side as my kids play I'm worried the PVC pipe will eventually get snapped.
    I'm thinking hard plumb upto a certain point the use hose and clamps to give it some moving room.
    Also I put I was so into getting the butterfly gasket trimmed that I didn't realize I had installed the skimmer a few feet from the return.
    Is that going to be a potential problem in the future?
    I might just cap off that return and put the new return further from the skimmer. I will be putting up pics as soon as I can get to my laptop.
    22,548
    Having the skimmer close to the return isn't a problem. Especially if you install an aimable eyeball. You can aim the eyeball so that the water circles the pool from the return toward the skimmer.
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Ok Well heres a pic of the skimmer, I might still move the outlet but it works fine still as is.
