The last 3 afternoons my water temp has been 92 degrees which is a little warm for me but thats another post. My question is concerning the % output for the Auto pilot. In the manual it says that the Auto pilot will automaticly adjust the out put based on the temperture, Low % out put for colder temps and Higher % out put for warmer temps. When checking the read out the last 3 afternoons the % out put has been at 0%. Each time I raise it back up to 50%. Is this normal or is this a sign that something is wrong with the cell? Cell voltage/amps has been running at 19/5. Also I have went from 6ppm FC to 2.5ppm FC. My Auto pilot was installed and started up in Apirl 08 and runs 24/7. My last set of numbers are as follows:
Time 7:40pm
Date 6-8-08
FC 2.5
CC 0
TC 2.5
pH 7.5
T/A 90
CH 70
CYA 40
Temp 92
Salt 3440
Time 7:40pm
Date 6-8-08
FC 2.5
CC 0
TC 2.5
pH 7.5
T/A 90
CH 70
CYA 40
Temp 92
Salt 3440
