Results 1 to 14 of 14
Thread: New Intex Sand Pump & SWG troubleshooting
    swtaspie's Avatar
    Jul 2012
    NE Ohio
    27
    I just set up my intex pool from last year with the new goodies, an Intex Sand Filter and Intex SWG.
    I'm feeling kind of dumb with the new set-up!
    The first day was great. Noticed a huge difference from last year!
    Second night the sand filter and swg ran we heard the swg alarm going off. Low Flow. The water level was nearly under the outlet hose. The pump was pouring water out around the 6-way and the pressure was in the high red. We shut it all off and and closed the plungers to stop losing water.
    Third day, we ran it and about two hours in the same thing happened, only we noticed sooner, so we didn't lose water or get the alert from the SWG.
    Next day two hours into it the pressure did the same thing, only this time it was followed but a nasty squealing noise.
    Today we ran it for about two hours and it did the same thing, 2 hours, high pressure, leaking, noise.
    Any ideas on what am I doing wrong here?
    Hubby was the one that hooked it up. Both Filter and SWG were leaking. We had to unscrew and reconnect everything before tightening everything with tools.
    Intex 12'x36" Ultra Frame AGP (1,779 Gal) | Intex Krystal Clear 12" Sand Filter/Pump (SF10110) | Intex Krystal Clear SWG (CS8110)
    Nearly-level with Sand & Tarp underneath.
    Pool Owner (Since July 2012) w/ 3 Happy Kids (13yrs, 9yrs, 4yrs)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New Intex Sand Pump & SWG troubleshooting
    What is the pressure gauge showing? Have you backwashed it yet? Backwash whenever the pressure goes up 25% from the clean pressure reading.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I'm going to ask a really silly question, or two, but I think they're definitely worth checking.
    Is the filter multiport set to "filtration"?
    Also, is your SWCG the last one on the chain before the water returns to the pool and the pump is 1st where the water is pulled out of the pool, with the filter in the middle?
    Also, check your in and out lines to be sure nothing is swapped anywhere.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Can you take a photo of your pool/pump/filter/SWG/pool setup? Back far enough to see all of it at once.
    -- Guy --
    swtaspie's Avatar
    Jul 2012
    NE Ohio
    27
    Quote Originally Posted by linen
    Hubby said we already backwashed it, twice today.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by techguy
    I second that!
    swtaspie's Avatar
    Jul 2012
    NE Ohio
    27
    I took a video of the setup and that noise. It's dark out, just waiting for the video to upload to youtube....
    Could not get a picture far enough back tonight but will get one in the morning.
    swtaspie's Avatar
    Jul 2012
    NE Ohio
    27
    Thank you all for helping. Love this place!
    Quote Originally Posted by y_not
    Yes
    Yes, that's the lineup we have! Pool sucking out (lower pool hole) -> into the sand pump -> into the SWG -> then out the higher pool hole. Both plungers are also open.
    LOL made that mistake and caught as soon we started it the first time! The SWG flow tube was reversed. Silly hubby!
    swtaspie's Avatar
    Jul 2012
    NE Ohio
    27
    Ok here is the video. Nothing is "on" at first. At the end I turned the sand filter on.
    http://www.youtube.com/watch?v=ENFjiPs6nPU
    I'm sorry its dark out and little wobbly. Two stray cats were happy to see my feet!
    I will do better tomorrow!
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    HAHA, no worries, anyone could goof up those connections on their 1st try. Hey, even professionals make mistakes sometimes, even rookie mistakes.
    Thanks for the video, quite usable, despite being dark. I see kitty wanted to help, or see what was up.
    1st thing, your tank o-ring that sits between the MP valve (6-way) and the tank is either missing, damaged or you left the sand shield in place, which should be removed after adding sand, that's used to aid in centering the center stand pipe while loading the sand. It should not be leaking water there at all.
    Shutdown the system, close the valves on the pool return and inlet ports. Take the head off of the tank and inspect the sealing grove on the underside of the MP. Make sure the gasket is there and intact /w no damage. Inspect for and remove any dirt or sand from the seal, seal groove and mating surfaces. Check for any obviously protruding casting lines that may have sharp or rigid edges preventing a proper seal, gently file them down, or cut them. Doing so such that you're far away from the o-ring that could accidentally be nicked by the slip of a knife. The thin little lines can be ignored, I'm referring to anything majorly obvious and in the way. Like the thorn in the giant's foot. Gently remove and inspect the seal if need be, don't nick it when removing it. Also go ahead and give it some clear silicon grease lubricant. Do not use any petroleum based lubes. They destroy the rubber seal.
    Next, check to be sure you didn't leave the sand shield on top of the tank, if so, remove it or it won't seal properly. Check that your sand isn't above the max fill line stamped on the side of the center stand pipe, also be sure It's at or above the minimum line.
    Next, reinstall the MP, making sure the stand pipe lines up properly with the hole in the bottom of the MP and that it seats correctly. Push down, making sure the 2 sealing surfaces between the MP and tank contact properly. No uneven contact, etc..
    Bolt it back togethr with the tank collar, double check everything is tight, but not overtightened.
    Fire it back up and see if at least the tank leak issue is resolved.
    As for your plumbing, it all seems fine.
    I have lots of SWCG tips for you, but that can wait until your pump is working. Speaking of which, until you get your pump working, you need to stay on the chlorine. You should be testing daily, manually dosing with bleach and brushing the pool to mix until you get circulation going again.
    You do have one of our recommended test kits, right?
    Thanks for hanging in there with us, we have got ya covered!
    Valve
    It also looks like there is water going out the exhaust/backwash you should be able to take off the cap and not leak
    The rubber seal came off mine and was doing the that also.
    It happened when I backflushed without turning off pump...oops
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    swtaspie's Avatar
    Jul 2012
    NE Ohio
    27
    Thanks for the responses. Off to try the suggestions.... (wish me luck!)
    Thanks look forward to that!
    swtaspie's Avatar
    Jul 2012
    NE Ohio
    27
    Leaking has stopped and the noise has not been back so far...! Huge thanks to y_not for all the help!
    Not sure what was causing it but we emptied the sand out and started all over using the tips you gave. Worked!
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Awesome possum! Glad to hear it!
    I'll be on later to give you tips on your SWCG. In the meantime, have you read pool school and do you have one of our recommended test kits?
    BTW, I absolutely love your avatar! Did you draw it?
    Enjoy!
    Tony
