Results 1 to 10 of 10
Thread: CYA testing, frequency and cost
    Wildcat's Avatar
    Jun 2013
    309
    From what I can gather the CYA test is costly and has a margin of error. How often does one test your CYA compared to FC and PH? How many CYA tests in a TF100 test kit?
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CYA testing, frequency and cost
    The tf-100 can do about 16 tests. I test my cya at the beginning of the season, one to two more times to check I have reached my target, then at most 2 more times during the season if I am worried.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I don't know about anyone else, but I only test my CYA if I've added more than 4" of water to my pool, or had to drain 3-4" from rain.
    Since I have the K-2006, I don't know how many tests you can do with yours.
    Duraleigh sells the reagent in an 8 oz size, better price than I've seen anywhere else.
    In addition to testing, you can estimate your levels based on past readings and what you have added. Fresh water added to replace evaporated water won't change the level of CYA. Fresh water added to replace water lost to backwashing, leaks, splashout etc. will lower the CYA level.
    Adding Cyanuric acid, trichlor tabs and/or dichlor powder will raise your CYA. The pool calculator will tell you how much the CYA is increased based on how much you add and your pool size.
    Support the site
    Jun 2012
    Howell, NJ
    977
    FWIW, you can buy the R-0013 in 16 ounce bottles for under $15 shipped. It is said that R-0013 lasts for a very long time.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Wildcat's Avatar
    Jun 2013
    309
    Where can you get R13 for $15 shipped? At TF it is like $17 plus shipping
    Jun 2012
    Howell, NJ
    977
    Amazon. Usually Amato has it, but I didn't see it on their website.
    John
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    For the $2, get it from TF. It's worth his help for the extra $2.
    -- Guy --
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    If you do a lot of testing its avail in larger containers at a discounted price, but for normal use I would buy from our local forum supporter.
    chiefwej
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I bought mine at Amato:
    1 x R-0013-E Taylor Cyanuric Solution (pint) #13 (309) = $6.86
    Test CYA about once a month.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
