Results 1 to 13 of 13
Thread: Motor replacement
    Motor replacement
    Hi everyone,
    Thanks in advance for any help.
    My current motor changed sound levels, upon inspection it is running hot and will need to be replaced.
    A.O.Smith B227SE 3/4HP SF1.00 230/110 Volts, FR. M56J Type CX
    My main questions are this:
    1. Is there a direct replacement that would be less on power consumption? One with a built in timer?
    2. Does my current motor seem the right size? Just seems small to me... Story of my life!
    I can get the exact motor for $135 + 14.95 with seal replacements. Free shipping. At that price if I got 3-4 year out of each pump it doesn't seem terrible. I do notice a decent bump in my electric bill when running this. The timer is broke so I know I run it way to much but until I get a new one installed I kind of expect the high electric bill.
    16X32 Vinyl liner 3' 5 - 10'
    26,000 gallons
    S-200 Sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Motor replacement
    Can you post the pump model number.
    Here is a picture!
    26,000 gallons
    S-200 Sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Is it a jandy stealth jhp?
    No its a Hayward ENCL3? That's all the markings I can see on it.
    26,000 gallons
    S-200 Sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I am getting nothing that I can find with encl3. Is there any other markings? Could you post a picture?
    Edit:just saw you pictures.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Okay looking at your pictures I think that sticker with the encl.3 is just a csa regulatory sticker. Can you take a wider view picture so we can see the whole pump?
    kyser's Avatar
    Jun 2013
    Orange City, FL
    47
    6.7K Pro Series 18x48, VL40T32 pump/filter, Hayward skimmer, TF100, and BBB!
    Here is the overview picture, I noticed the shiny sticker but looking at it nothing is etched / stamped in it.
    26,000 gallons
    S-200 Sand filter
    Knoxville, TN
    41
    B227se is 3/4hp motor for hayward superpump.
    Hot Springs certified service tech A
    APSP CST Certified
    CPO Certified
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I agree that is a hayward superpump. But the motor has me perplexed. It has a really low amp rating compared to other similar sized motors listed for use on the superpump [s:16r9nf8c](such as the ust1102).[/s:16r9nf8c] Sorry that should be ust1072 and that one is listed as 11/5.5 amps. May just be specmanship. Do you know if it is wired for 115 or 230 volts?
    the pool goes to 1 20AMP breaker so I am assuming its 110?
    26,000 gallons
    S-200 Sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yes, then 110. So I am fairly certain this is a 2-speed motor for you pump: http://www.poolsupplyworld.com/Centu...-115V/B971.htm
