Results 1 to 8 of 8
Thread: intex ultra frame & SWCG? maybe not good idea?
    tookiesmom07's Avatar
    May 2013
    Tennessee
    56
    Just a question of interest since I've thought about going SWCG next summer since our yard is sun covered nearly all day and our working hours horrible so trying to keep chlorine levels decent could be a nightmare. While searching nonlinear for a good, affordable SWCG pump, I came across a review of someone who went salt on their intex ultra frame pool and the "t"'s rusted out so bad they became unusable due to the saltwater. Has anyone heard of this problem or have this happen to them? Just curious since I wouldn't want to go the SWCG route if that's a problem.
    Intex Ultra-Frame 26x52 AGP (14,650 gal.)
    Intex Pump & Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: intex ultra frame & SWCG? maybe not good idea?
    There are a few reports on here of people with intex ultras and rusting problems, but there are also many with ultras and swgs without problems.
    Jun 2013
    Newcastle, Oklahoma
    508
    i was going to go SWG on my new intex ultra, but when i upgraded from cartridges to the Intex 2650 sandfilter, the manual says "not for use with salt water generators" so, from my understanding, i cant have one anyway.
    at any rate, i dont see how that would rust out the frame, as the salt ppm is so low in a SWG pool....
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I think the 2650 sand filter will be fine with a swg and many on here are doing it.
    May 2013
    Tennessee
    56
    I was thinking of upgrading to the 2650 sand next year but if it can't be used with a swcg, I may have to look into something else.
    Intex Pump & Filter
    Mid Missouri
    227
    The manual states not to use the pump with one particular model of swcg. However it is not a model I'm familiar with and not the one that it appears most people here have. I'd verify which swcg unit you have. If its the Krystal clear saltwater system that is more commonly discussed around here; I can verify the pump works fine with it and its not the model specified as not compatible.
    As far as the rust; I don't know. I've got the 18'x48" easy set, so no rust concerns here.
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
    Mid Missouri
    227
    To be more specific the manual states not for use with- kcp low salt automatic saltwater system model 6110/6220. I've not seen that unit discussed here before, and appears to be pretty obscure from my quick google search.
    So everybody planning on going with the common Intex Krystal Clear Saltwater system model CS8110 or equivalent,no need to be alarmed. Proceed as planned.
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by jcp
    cool. thanks. i may upgrade to the KC SWG next season. MAYBE.... ive got a good thing going on with this BBB method... pool couldnt possibly be clearer.....Ive always leaned on the side of not messing with a good thing....
