Thread: Cloudy Water
    Cloudy Water
    5300 k gallon, AB vinyl, cartridge filter, installed 6/30/13.
    I tested Sunday. Had pool store check as well. They tested everything all levels are good.
    Its our first pool and have no idea how to fix this.
    Thank you,
    22,542
    Re: Cloudy Water
    Welcome to TFP.
    What brand of pool and filter do you have?
    What size pump do you have?
    Post the numbers from the tests. Telling us that thay're all good doesn't help us figure out what's wrong.
    Have you been running the pump and filter 24 hours per day?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Cloudy Water
    If you have cloudy water chances are all the test numbers are not GOOD, either that or the test were not done right, which is a coin toss either way when dealing with pool stores
    Re: Cloudy Water
    I have the Summer Escapes 18x42 pool.
    The pump is a 1500 GPH
    I run the filter all 24hrs and the saltwater system in 12hr intervals.
    Test Results:
    Free Chlorine 3.00 ppm Total Chlorine 3.00 ppm
    Combines Chlorine 0.0 ppm PH 7.4
    Hardness 160 ppm Alkalinity 110 ppm
    Cyanuric Acid 30 ppm Copper 0.0 ppm
    Iron 0.0 ppm Total Dissolved irons 1000 ppm
