Thread: Pool Factory - Quest Oval 15x30x54
    I am in the process of installing my Quest pool and I am considering using a Salt Water System.
    Does anybody in the forum with the same pool use a SWP?
    Thx
    Pool Factory model Quest (oval: 15x30x54), OptiFlo Plastic Pump, Starbright Filter System.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Pool Factory - Quest Oval 15x30x54
    I show Quest pools are made by Wilbar. You can use any large SWG generator with that pool and it's use is common here.
    Post up your filter and pump selection/options and your location and someone will help you determine which is the best brand and capacity for your needs. Will you have 240v electricity at the pool?
    -- Guy --
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, luizflo3636
    My recommendation would be to start using manual chlorine dosing methods taught here at tfp first, then when you get a hang of the pool chemistry, then decide if you still want a Salt Water Chlorine Generator (swg).
    You may want to check with quest about their pool warranty when used with a swg.
