Thread: Vacuuming/Sand Filter
    Oct 2011
    Chicago, IL
    113
    I have noticed that sometimes when I vacuum my pool, the returns seem to pump in cloudy/debris in water. Only happens when I pump the pool. Is this bad for my pool? How do eliminate this problem?
    I have a 35,000 gallon, sand filter, sunken above ground (so inground), vinyl liner, with an Aqua rite turbo cell SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Vacuuming/Sand Filter
    It likely is not bad for you pool, but will affect the water clarity. It may be that the stuff is bypassing the filter due to a bad spider gasket in the multiport valve...do you have a multiport valve? If you do, I would pull the valve and inspect the spider gasket and the sand for clumping.
    Butterfly's Avatar
    South Carolina
    10,045
    When was the filter last cleaned? Maybe the sand is channeled:
    my-sand-is-channeled-how-to-fix-it-t7626.html
    You're done SLAMing when:
    Oct 2011
    Chicago, IL
    113
    I have no idea when the sand filter was last cleaned, I bought the house in 2011 and havent cleaned it since. I definitely do have a multiport valve. I am wondering if I should just wait until I close the pool down to look into these issues. Everything else seems to be working fine so I dont want to mess that up. But if this could create future issues then i'd like to get that taken care of. Any other thoughts regarding why this might happen or if it is bad for my pool?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Is your mupltiport connected to the plumbing with unions? If it is, then it is fairly easy to do, and I would do it now. If not...then I would probably wait, since it would involve redoing some of the plumbing. If you want, snap a picture and post it here.
