Results 1 to 14 of 14
Thread: Cannot get my CYA level to increase
    Jun 2013
    Louisville, KY
    65
    I have added CYA twice now. A few weeks ago I added 40 ounces and a week later it tested around 20, probably under that. I added another 32 ounces about a week and a half ago and I can still see the black dot, granted it's really really light gray. We have had quite a few rain showers during all this time. Could this affect it? All my other levels look pretty good.
    CC- changes daily I have to add bleach every day
    FC- .5 or lower
    pH- 7.8
    TA- 90
    CYA- low low low
    Could I have something growing in my pool eating my CYA? I'm at a loss. When it's not raining it's been very sunny and humid. My pool is in direct sunlight all day and the water temp is usually 86-88 degrees.
    21ft round Doughboy AG, 9,300 gallons
    22 inch ClearWater Sand Filter
    1 HP Hayward Power Flo Matrix Pump
    Install 6/16/13
    TF-100 Test Kit
    38,463
    Re: Cannot get my CYA level to increase
    How does the water look?
    Are you maintaing higher FC values than you indicated?
    So, what are your CCs? Are they greater than 0.5ppm?
    The the CYA is getting broken down, that is usually indicated by high CC values.
    With 4.5 pounds of CYA added, it should be reading up around 50ppm.
    22,553
    What was the percentage of CYA listed on the ingredient list?
    We've had reports of some 50% stuff, and if that's the case you'd be just about right with 25 ppm so it'd be cloudy right at the top.
    Jun 2013
    Louisville, KY
    65
    The water is crystal clear.
    FC is always .5, it barely turns pink, 1 drop brings it back to clear
    CC will go from 3 to 0 in 24 hrs. I know, I should be shooting for alot higher when adding it. I have to get more bleach.
    The CYA is 99%
    Install 6/16/13
    TF-100 Test Kit
    Feb 2008
    Denton, TX
    5,061
    Hopefully, you got some half strength CYA and that is the cause of your situation. Do you happen to have an auto-fill on your pool though? Sometimes, the presence of an auto-fill can mask a leak that is causing your CYA to drop.
    Jun 2012
    Howell, NJ
    977
    I think you have your chlorines backwards. You raise your FC (free chlorine) with bleach, and you always want CC (combined chlorine) to be less than .5. FC is what you test for first, then you do the CC test.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2013
    Louisville, KY
    65
    Yes, sorry. I'm at work right now and secretly posting, lol. I did reverse my FC and CC.
    What is auto-fill? I don't believe I have that.
    Install 6/16/13
    TF-100 Test Kit
    Jun 2012
    Howell, NJ
    977
    An auto fill is a device that keeps the water level the same automatically. I don't think they make any for above ground pools, but I could be wrong.
    John
    Jun 2013
    Louisville, KY
    65
    I guess I will just wait a few more days to test CYA again. It did take about 4 days to dissolve so maybe my reading will change.
    Install 6/16/13
    TF-100 Test Kit
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I hope Richard (ChemGeek) chimes in after this comment because he would definately know the answer to this but........ I have been told (and mind you have not confirmed this), that if your pH is too high when you test your CYA level, that you can get a low CYA reading. The reason for this is that if your water is too basic (high ph), the Cyanaric acid comes "out of solution" so you don't get an accurate reading. Now, this doesn't mean you have "chunks" of solid CYA floating around in your pool. Just microscopic solids that aren't reading on your test. Get your pH lower (more acidic) into the proper range and your Cyanauric Acid will go "back into solution"
    Richard, if your are reading, please comment.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2013
    Louisville, KY
    65
    Makes sense, I will wait to see if Richard comments. I was planning on adding a little muriatic acid to lower my pH some. Thanks!
    Install 6/16/13
    TF-100 Test Kit
    30,431
    Incorrect. pH has little to do with the CYA test.
    Mar 2007
    San Rafael, CA USA
    12,082
    Dave's right. The pH does not affect the CYA test. There is an acid buffer in the CYA reagent that forces the pH down to force full precipitation of melamine-cyanurate so any typical pool pH will be fine as a starting point. There was some question at some point with whether a high FC might affect the CYA test, but we determined it wasn't (in this thread).
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Thanks Richard. That's why I defer to the expert.
