Results 1 to 7 of 7
Thread: Hard plumbed my AGP
    Jun 2012
    Howell, NJ
    977
    Hard plumbed my AGP
    So this is my 600th post, and I decided to make it something special. I will show you my hard plumbing on my pool. My dad gets all of the credit for this, because it was his idea and he did all of the work. Enjoy. One question for you, I think I may have a leak. Does a 1" water loss in 24 hours with a solar cover on all day sound normal to you?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Hard plumbed my AGP
    That drop in pool level seems high. I would do the bucket test to confirm.
    Tell your dad, nice job on the plumbing
    Where do the pipes go that come out of and go into the ground?
    Jun 2012
    Howell, NJ
    977
    Quote Originally Posted by linen
    Those are support pipes. Keep some weight off of the fittings. I'm planning on doing the bucket test, and I know the perfect bucket. I just have to stop being lazy and clean it off.
    John
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Make sure you have access control to the yard. A child could use that plumbing as a ladder to get into the pool.
    Feb 2013
    Yukon, Oklahoma
    220
    John, make sure and tell your dad (and you too) great job on the plumbing. Really nice and clean.
    Water loss. Is that "hose" is see connected to the white valve used to add water to the pool without throwing a hose into the pool? If it is, that's probably your problem. There may be enough suction after turning the water off to suck the water back. I can't remember exactly what they call it, but I know if you leave a hose in big thing of water it can siphon it back out.
    Bob E.
    Jun 2012
    Howell, NJ
    977
    That's the hose that goes to my DIY heater. Here is the full heater setup: thanks-to-bbb-my-pool-looks-like-this-t51476.html?hilit=heater
    John
    Jun 2012
    Howell, NJ
    977
    I'm going to have to do something about this leak, because, since adding ~2" of water over the past 2 days, the pool is starting to turn green (not algae, it's iron). I'm also probably going to be using A LOT of Borax to keep my pH in line. I'm trying to do the bucket test, but I am going to have to find a nice clean brick to hold the bucket down. It keeps floating away.
    John
