Thread: HELP! TH test turns Yellow!
    Apr 2013
    Buffalo, NY
    29
    I have the htc 6 way test kit. Yesterday I tested everything. Everything was spot on. Today, when I test the TH, I put the 25mls in the tube, put in 5 drops of hardness indicator and it doesn't red, it turns YELLOW! Adding Titrant doesn't change the color to anything else. It just stays yellow. What's wrong?
    Thanks in advance.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: HELP! TH test turns Yellow!
    You're done SLAMing when:
    Jun 2012
    Howell, NJ
    977
    The hth test tests for TH, not CH specifically. Back when I used the hth kit, I always had this problem too. I don't know if there is really anything you can do about it.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Apr 2013
    Buffalo, NY
    29
    IDK, maybe...Total hardness. Yesterday the water turned red and then blue when I added the second step. But today, it just keeps turning yellow with the indicator. too much chlorine? It's slightly elevated at 5.
    38,275
    5ppm is not "too much chlorine".
    Are you sure you are using the correct reagent .... would not be the first time someone just grabbed the wrong bottle.
    Apr 2013
    Buffalo, NY
    29
    No, I'm using the correct one. I've tried a few times over to be sure I was grabbing the right bottole. Same results. The first time I did it, it was fine. I just did it today and it was fine.
