Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: New Pool Build Plumbing Diagram
    May 2013
    Round Rock, TX
    138
    Curious as to others thoughts on the plumbing? I know the builders reason behind reducing to 1.5" on the far returns. He says he needs to increase the velocity at the far returns. My understanding is that'll actually increase head and cause the pump to work harder. Thoughts? Does it really matter in this case?
    Attached Files Attached Files
    35'x16' IG geometric with 8'x6' spa (16.5K gallons); White Diamond Pebblesheen w/Abalone Shells; Jandy 460 cartridge filter; Jandy 2HP E pump; Jandy 400K heater; Water Tech Blue Diamond Pro; TF-100 w/SpeedStir
    Jun 2013
    Huffman Tx
    190
    Re: New Pool Build Plumbing Diagram
    You need to hav him go all the way around and connect it together , the return line should be a looped all the way around the pool for even pressure . that how my plumber did it
    Ideally you want more things having their own pipe run back to the equipment pad, and 2" pipe through out (except larger for the spa as shown). Pipe is cheap, so it doesn't make that much sense to plumb a pool this way. That said, this kind of plumbing is fairly common, and it does work (if balanced correctly). It just that given the minimal extra costs it is clearly better to do it a more modern way.
    You appear to have dual main drains connected to the left hand skimmer? If that is correct, that is more than worth changing. It is a huge advantage to have the main drain plumbed separately back to the equipment pad.
    On the returns, it is very difficult to balance the returns when they are plumbed that way. It can be done that way, but usually they end up unbalanced. Since the return pipe already goes 3/4 of the way around, it seems worth running it the full way around into a loop as vinper suggested. That will automatically balance the returns with little effort and minimal additional cost. If looped, it should be 2" all the way around.
    Using 1.5" in the line to the far returns as drawn isn't a great idea, though it does have some justification. The additional water velocity in the pipe doesn't help anything. You get your jet velocity by controlling the opening size on the return eyeball. The way in which it makes sense is that as you pass each return, the amount of water going through the pipe goes down, so you don't need as large a pipe. With careful choice of return eyeballs (with the ones closer to the pump having smaller openings) the system as drawn could work out. But I would never do mine that way.
    The skimmers will also be unbalanced. Ideally they should each have their own run to the equipment pad and each have their own valve at the pad.
    May 2013
    Round Rock, TX
    138
    Quote Originally Posted by vinper
    I thought the same thing, but from I've read several different topic posts that's indicate its much more important to loop the returns on a spa than on the pool.
    May 2013
    Round Rock, TX
    138
    Can you give me an example of why? Just want to provide some justification when I ask him to change.
    Jun 2013
    Huffman Tx
    190
    yes ,I agree seperate main drain , no flex pvc under pool . ran mine with 2.5" for less restriction on pump .
    Jun 2013
    Huffman Tx
    190
    Having the main drain plumbed to the skimmer is next to useless. No water will be drawn from the drain unless both skimmer baskets are completely full. If you run the main drain back to the equipment pad, you can turn off the skimmers and use the main drain to drain the pool below the skimmers, something that is impossible as shown in the diagram.
    May 2013
    Round Rock, TX
    138
    Jason, in doing some research, I think most skimmer ports have two ports for the very reason of tying your main drain to the skimmer plumbing. They then have a valve system with a float that closes the skimmer port and diverts completely to the main drain if water drops below the tile line. I do agree that best practice would be to run individual lines from each skimmer and the drain so as to be able to manually control each in case of issues with one or even two lines.
    38,275
    Yes they all have 2 ports to allow for this, but it does not mean it is the best solution.
    In fact, even if you do plumb the floor to the pad, you should ideally have an equilizer line plumbed to the 2nd port in the skimmer as a backup source of water if the level got too low.
    The advantage of the separate lines is better flow control and the ability to only use the floor if you needed to drain the water below the skimmer line ... the floats diverters are not typically air tight.
    May 2013
    Round Rock, TX
    138
    I confirmed with my builder that there are two suction lines back to the pad, one from each skimmer. He does have the main drain tied to the deep end skimmer. I'm trying to decide if I'm going to push to have the main drain plumbed separately.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by bzeller
    That's true. The longer the loop, the less you benefit from the loop. But when using small pipe, a loop is better than no loop. Although, you can also accomplish better balancing by just up sizing the pipe size. But downsizing the pipe to 1.5" for the far returns makes no sense at all as it will make the imbalance far worse.
    Mark
    May 2013
    Round Rock, TX
    138
    $445 additional to bring a dedicated main drain line directly back to the pad. Worth it?
    $280 to upgrade the return to 2.5" all the way through, not looped. I'm leaning a definite yes to this since it's about 160 ft of total pipe.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    417
    $445 seems kinda high for the price of pipe and work involved. It goes in the same ditch as the returns.
    Yes you want the main drain separate. Also allows you to shut the main drain off if your using a vacuum.
    And you reduce to eyeballs to get the flow you want to properly skim the water. 3/4 inch is common.
    I also prefer screw in pool fittings VS press in - I use screw in plugs to winterize and for directional water flow eyes.
    2" all the way around is good.
    And the quality and power of the pump and routing at the pad effects flow- variable speed pumps are best as you can adjust the flow for your spa etc.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    May 2013
    Round Rock, TX
    138
    I thought so too and pointed out the same thing. The plumber charges $X/ft of pipe and that's what it comes out to be. I said do it, but under protest!
    Bzeller, you are right. A smaller pipe will have a lower flow. The velocity will be higher but the flow will be lower. The flow is lower because there is more resistance in the smaller pipe. Go outside and try it with a nozzle on the end of the hose. The small jet won't have as much flow as the full open hose end (with the same spigot setting). May or may not matter. Is the final section on each run reduced to 1.5"? if so there may not be all that much difference in flow.
    May 2013
    Round Rock, TX
    138
    It's now a 2.5" pipe to all returns.
    Jun 2013
    Huffman Tx
    190
    my increase to 2.5" was on the bottom drain to pump for less suction restriction
    May 2013
    Round Rock, TX
    138
    I have 2" coming from each skimmer and the main drain so that puts me at 3 2" suction back to the pad. I believe that equates to one 3.1" suction pipe feeding one 2.5" pipe which shouldn't be a problem!
  20. Back To Top    #20
    Jun 2013
    Huffman Tx
    190
    I think it will be either or . Either skimmers or main drain not both ,mine go to a 3 way valve at pump . but 2.5 at pump is good.
