Thread: Gaskets and face plates
    Im in the process of putting in a new liner (16x32 sand bottom)
    Does everyone buy the gasket kits?
    I have 6 spots - around fiberglass stairs, two returns, skimmer, main drain and deep end light
    I have really only found a kit for the stairs, so im wondering what to do for the other spots, how to glue.... etc
    or maybe everyone just uses whats already attached?
    20x40 in-ground vinyl liner, 34k gallons, hayward 244 sand filter, heater, 2 outlets, sep skimmer and main drain plumbed to a valve, BBB method, hayward super pump 1hp
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Gaskets and face plates
    When I replace a liner I replace all the cork gaskets which are typically the skimmer, light, main drain, steps and returns are usually a black rubber. I don't typically replace those unless they are damaged. Just make sure to secure those gaskets in place so they don't shift out of place during the liner installation for example pool wall foam glue or duct tape
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
