Ok, I have had the Liquidator for several weeks and overall things are working well. I did contact HASA because my flow meter had a crack, and they quickly sent me a new one. However, I was wondering if my flow meter is working correctly. When the pump is on, the ball is at the set level (between 2 and 3 in my case), but there is air above the ball in both cylinders. Is that normal, or should both cylinders be filled with water?
Overall, I am happy with the liquidator. Its keeping my pool crystal clear.
