Thread: pressure
    pressure
    Hello everyone,
    This is my first post. About seven months ago I moved into a place with a pool, so I have been trying to learn things fast. This evening I noticed that my pressure was around 20psi (my local store said that it should be around 13). I did a backwash for about 3 minutes and rinsed for 30 sec. I actually did this twice just to be sure. This lowered my water level below the skimmer so I have brought it back up, but my pressure is still around 18psi.
    I have also noticed some water coming from around my pump which scares me to death!!
    Thanks, and try to break it to me gently.
    --Trident
    25k gal, gunite, intelichlor swg, sand filter, 1.5 hp
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: pressure
    Your local pool store is full of idiots, normal operating pressure will depend on a number of factors, location of pump and filter, length of plumbing, number and size of fittings, etc. Around 20 psi may be perfectly normal for your pool, it is a bit above average, but not too much. As to the leak you have, if you lowered the water below the skimmer while the pump was running you may have ran the pump dry and over heated it, potentially damaging the pump or partly melting the lines going into it.
    Ike
    Medic3's Avatar
    Jun 2011
    Missouri
    42
    Re: pressure
    What is your pressure normally? Are you getting normal pressure out of your returns? My filter pressure runs around 17 with a clean filter -this year. My base filter pressure changes from year to year. It depends on how old the my gauge is or how well i clean the filter in the spring. If you have back washed twice then the filter is clean.
    As far as the pump you need to figure out where the water is coming from. Is it a fitting, the strainer basket lid, or between the housing and the motor.
    20,000 gal. 27' AGP
    Hayward 18" sand filter with 1 hp Hayward Matrix pump
    A convinced BBB user and TFP fan
    Re: pressure
    Thanks for the input.
    As it turns out, I had messed with the adjustment on my fountain, which affected my pressure. It is back down to normal now.
    Learn something every day!
