Results 1 to 13 of 13
Thread: Intex adapters to pvc
    Jan 2013
    Aruba
    229
    I have seen here some people use the nuts from the plungervalve and some use the hose nut,just wondering which is easier to make?
    Also i was thinking of cutting the whole coupling from the hose,and using the coupling with the nut as the adapter.
    Just wondering if the intex coupling will fit in a 2"pvc so that i can glue them together?
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Jan 2013
    Aruba
    229
    Re: Intex adaperts to pvc
    I want to know if i can use the coupling with hose nut that is on the strainer pot as the adapter and just cut the hose off and glue on a 2"pvc
    Thru wall skimmer,
    Hard plumbed
    May 2012
    Baltimore, Maryland
    183
    the nuts from the plungers are two pieces, the nuts from the hoses are one piece.
    either one works, the two piece ones are better in my opinion as you will not need to cut anything to remove them or if you need to remove them from your pvc later you dont need to cut your pipe.
    15'x4' Metal Frame Intex 3yo (2nd year winterized) 16" 2650gph intex sand filter, Thru wall skimmer, dual inlet/single outlet, 1000gph intex pump (heater) Solar Cover TF-100 testkit, TFPC
    May 2012
    Baltimore, Maryland
    183
    Re: Intex adapters to pvc
    I think that would work, just leave the smooth part of the hose and glue into your slip fitting, should work.
    Jan 2013
    Aruba
    229
    Ok thx,but do you think that the intex coupling will fit in a 2" pvc coupling?
    Thru wall skimmer,
    Hard plumbed
    Jan 2013
    Aruba
    229
    i just nervous for cutting the hoses ,but yeah it should work.
    if i use 2" pvc then i can connect the "main drain' and the skimmer to the pump because now i can only run one at a time
    Thru wall skimmer,
    Hard plumbed
    May 2012
    Baltimore, Maryland
    183
    the lip on the end of the hose which keeps the nut from falling off should be the same size as the second smooth section right before it changes into flex hose, you could unhook and see if it fits inside a slip fitting before cutting and glue.
    measure twice, cut once
    Jan 2013
    Aruba
    229
    How do u mean unhook it?
    Thru wall skimmer,
    Hard plumbed
    May 2012
    Baltimore, Maryland
    183
    measure the circumference of the coupler.
    then compute
    circumference (divided by) 3.14 (pi) = diameter.
    May 2012
    Baltimore, Maryland
    183
    where your hose hooks onto your skimmer. see if it will slide into your slip fitting or if it looks close.
    you could cut just the lip off the hose that is connected to your skimmer since your already not using the nut and see if it will slide into a 2" slip fitting if you wanted to know for 100% sure without damaging anything beyond repair.
    Jan 2013
    Aruba
    229
    Ok thx i'll try it tomorrow but i think the hose it too big but i'll check it out
    Thru wall skimmer,
    Hard plumbed
    Feb 2013
    Yukon, Oklahoma
    220
    Without sounding like a jerk, why aren't you just using the standard 1 1/4 to 1 1/2 box adapter that has been the source of multiple threads (and successes) coverting from hose to PVC? I cut my hoses in half, and just had to be a bit careful holding the nut and adapter together with gluing that stuff into a 1 1/2 inch PVC fitting.....
    I do agree that the 2 piece nuts are far more user friendly but much harder to find these days.
    Bob E.
    Jan 2013
    Aruba
    229
    I can't seem to find them here where i live,and i'm just wondering if there are more ways to easily build the adapters
    Thru wall skimmer,
    Hard plumbed
