Results 1 to 8 of 8
Thread: AquaRite--New Install--Is it going to Spontaneously Combust?
    Not really--but...I am hoping to get some feedback on whether it is typical for the Control Unit to be so hot to the touch. Just installed the unit myself and it is running fine generating chlorine as it should. I finally got all the salt in the pool and turned it on. I needed to shock the pool and I was down to my last gal of bleach so I turned on superchlorinate mode. The only thing of particular concern is that the housing of the unit is hot to the touch. I understand that there is a transformer inside and that heat will be generated but it was hotter than I would have expected while generating.
    So...how hot does the housing get on your unit @ 100% output? Should I be concerned?
    Cwoody
    Jun 2007
    SF Bay Area
    441
    G-Coop,
    How hot is hot? Is the housing too hot to keep your hand on it for more than 5 or 10 seconds? And what is the ambient temperature? Is the unit in direct sun?
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Thx for the reply.
    The unit is in an enclosed 5'X8' "pumproom" so its not in the sun. The last few days, with the 98 degree temps here in the east, it has been well over 90 degrees inside that room. I can put my hand on the housing and not get burned but after 5-10 seconds it is uncomfortable. I could probably leave my hand there longer. Hopefully this gives you an idea of how hot it is.
    A side note: When the unit is in the off position it is only warm to the touch. But running at 100% is when it gets hot. When I left for work this morning I set it to Auto where I currently have it set @ 50%. I am expecting that the unit will not be as hot as it was. We'll see if that plays out this evening.
    Cwoody
    Jul 2007
    Alamo, CA
    187
    It wouldn't surprise me if it gets that hot, but I don't have direct experience with it. Given it uses a large transformer to step down the voltage (not the most efficient way to step down voltage) and it's running more than five amps through the cell, I'd expect it to get pretty darn warm.
    blubluenoiseise
    My pool: 14,750 gallons in-ground plaster
    FAFCO Solar panels (seven 4' x 12') with a Goldline automatic controller
    1/2 HP WhisperFlo filter pump, Kreepy Krauly cleaner, Cartridge Filter
    Aquarite SWG, Satisfied user of the TF-100 Test Kit
    Jul 2007
    Brisbane, Australia
    874
    It's normal for a transformer based SWG to get to 70 deg C inside the box if running at 100% output and the ventilation is poor.
    I have a Pro-Logic PS-8 - the Aquarite's big brother - and in the manual they specifically said not to enclose the case in a small area, because it acts as a heat sink for the transformer. It's probably the fact that it's in your pump room and not getting good airflow that is causing it to run hot.
    10k gal gunite inground w/ raised spa, waterfall, Hayward Super 2 1.5 HP 2 speed, Hayward 48 ft2 Pro Grid DE, Goldline PS-8 automation system, Goldline T-15 Salt Cell, Raypak 337k BTU LowNox Heater
    Jun 2007
    SF Bay Area
    441
    For those of us still laboring under antiquated systems, that would be 158 degrees F. Definitely hot to the touch.
    Titanium
    Re: AquaRite--New Install--Is it going to Spontaneously Combust?
    Thanks for the replies everyone. If indeed the Aquarite is using the case as a heat sync as the pro-logic unit does that makes sense. Being that its from the same manufacturer and considering my enclosed area with limited airflow I feel better now. I may actually rig a cooling fan up to it at some point to help pass some air over/through the unit.
    Cwoody
