Results 1 to 11 of 11
Thread: The other extreme - very LOW chlorine demand!
    Aug 2011
    Northville, Mi
    312
    Okay...this is now too good... After shocking a couple of weeks ago, my water is simply spectacular. I mean crystal clear. My CYA is at 40 while I wait for the FC to come down. When I quit shocking about 12 days ago, it was at around 19. This morning it's still only at 6.5! And we've had a few pretty sunny days and swam a fair amount. It got to about 10 maybe a week ago and is just crawling downward. We swam a couple of hours yesterday and got some sun, yet only lost 0.5.
    It was 90 and mostly sunny today, but I didn't check it this evening (I usually just check in the morning). I've even taken to running the pump for 30-40 minutes before checking, just to make sure it's stirred up good.
    So...what sort of freakish thing is going on with this? I don't want to look a gift horse in the mouth, it's just crazy...
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: The other extreme - very LOW chlorine demand!
    I think your fine. Don't sweat it.
    Jeff
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Granted, my pool is much smaller, but there are days that I don't need to dose with bleach, and my CYA is only 30 currently. Pool is shaded most of the day, with only a few hours in the early afternoon that I get full sun. I also try to keep my FC on the high end of the charted level.
    What you currently have is a great thing. Do keep testing daily. Don't expect it to last forever.
    Congrats for having a great pool!
    Odds are your CYA level is actually a little higher than you think it is, or your pool is really well shaded.
    Regardless, enjoy
    Aug 2011
    Northville, Mi
    312
    Regardless, enjoy
    That's what I was thinking, so I keep testing it to see if it's higher. Keep getting the same result!
    I get direct light on the entire pool from probably around 10am to 6 or so. Then some trees start obscuring part of it.
    As a side note, I keep making comments to my family..."Who takes care of your water? They do an excellent job! This water is amazing!"
    The responses---
    My daughter (with an occasional eye-roll): "You do daddy!"
    My wife (with a crooked smile): "The pool boy."
    Mar 2007
    San Rafael, CA USA
    12,082
    Are you sure your Intellichlor IC40 is really turned off?
    Aug 2011
    Northville, Mi
    312
    Quote Originally Posted by chem geek
    Not only was it turned off, I set the percentages to 0. Yesterday I actually decided to turn it back on at 5% on the offhand chance that having it off and at 0 would make it operate in some weird default mode. That will only add 0.2/day (the pump is running 10 hours/day right now). Lo and behold, this morning the FC is at 3.2 (I used the 25ml) after being at 6.5 yesterday. So...maybe my hunch was right?
    In any case, quick basic question - if I added CYA (liquid) this morning, it should bump it up to around 60-65. Will that additional CYA now bond to an extra amount of FC, taking my actual FC down farther? Is that the way that works? So should I bump up the IC40 a little extra today to feed the CYA *and* the sun?
    Mar 2007
    San Rafael, CA USA
    12,082
    That's weird that having it "off" and with 0% might have had it actually on, though it would be consistent with what you were seeing.
    A higher CYA level for the same FC level will lower the active chlorine level. For your saltwater chlorine generator (SWCG) pool, just make sure that your FC is at least 5% of the CYA level at all times. Even with a proportionately higher FC level, a higher CYA level will result in a lower absolute FC loss per day which is why we generally recommend 70-80 ppm CYA for SWCG pools. See Recommended Levels and the Chlorine / CYA Chart.
    Apr 2013
    Westside LA, CA
    49
    well, what's the water temperature? with cover and low water temp I observed very low chlorine demand in the past (pre swg days) as well.
    Just touching the swg panel with transformer inside tells me if it's working/generating or not.
    32x15 IG Borate+Salt, Pentair VS+SVRS, howard swim pure 40 SWG, Pentair 4000 48sqft DE, Mastertemp 300, Electric Pool Cover, Polaris P93, 4 Kids for Aeration, ;)
    May 2013
    Bay City, Michigan
    283
    I know chem geek posted a breakdown of chlorine demand from swimmers in a pool and it was quite low. Nothing compared to a hot sweaty small hot tub. He has too many posts for me to find it, but basically you needed quite a few swimmers for an hour just for a 1ppm demand.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Mar 2007
    San Rafael, CA USA
    12,082
    One person-hour of swimming in 10,000 gallons is around 0.1 ppm FC chlorine demand assuming no one intentionally urinates. One cup of urine is equivalent to 6-7 person-hours of swimming. So in most residential pools, bather load can be ignored unless you have a swim party or have kids (or others) urinating in the pool).
