Results 1 to 7 of 7
Thread: How close is too close?
    Jun 2013
    Southeastern British Columbia
    79
    Hi there. A question for you...
    In your opinion, how close is too close to palce the pool next to the house? Our house is built on a slab none of the house is underground.
    Pool is ultra frame type and we are planning to dig a space about 2 feet into the ground a couple feet larger than pool size and we are building a retaining wall within there. Then building a deck all around.
    Trying to decide placement asap
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    Casey's Avatar
    SW PA
    10,421
    Re: How close is too close?
    Well... How close is too close for YOU??? if said pool would burst, out of control, rushing water into your house?
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Ive seen a pic or 2 in these forums of intex pools a foot or 2 from the house.
    If you have no basement and are digging down 2 ft I would say get as close as you feel comfortable with.
    My pool is about 10 feet from my house, but I have no choice but to have it where it is. Half of my pool area is my neighbors property, but they don't mind at all.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    Jun 2013
    79
    Nice neighbors !! We have some neighbors who are great and then there is one who is far from great!! I could write a book about all the issues ... Lol
    As for the pool, we want to have as much usable yard remianing as possible for a veggie garden. Also want to keep the deck to a minimum.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Civil engineering says angle of repose + 1/3 distance. since you are digging down, this means no closer than about 3 feet to the house. Still not much room between pool and house.
    Jun 2013
    79
    Quote Originally Posted by Charlie_R
    not sure I understand what angle of repose + 1/3 means?? can you explain a bit more?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Check this article about angle of repose.
    Picture your house edge as being the top of a stockpile, and consider the dirt to be a loose conical pile. From the edge of your house, you move outward to where the base of that stockpile would be.
    You want to be at least the distance of where the base of such a stockpile would be plus 1/3 of that from what would be the top of your pile, if it was all loose dirt.
    The reasoning behind this is if something should collapse, it won't take part of your house foundation with it, in the case of a hole.
    It is figured both ways. If you had a basement, and were adding in an above ground pool with no dig, you would need to be at least that same distance described from the vertical wall of your basement.
