Results 1 to 8 of 8
Thread: intex swcg calcium or salt?
    May 2013
    Chandler Arizona
    78
    anyone else have this build up problem. seems I need to soak with vinager weekly?
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: intex swcg calcium or salt?
    Post a full set of test results including ph, TA, CH, and cya.
    Unrelated, but...Is that the intex swg? Do you have your copper bars unplugged?
    May 2013
    Chandler Arizona
    78
    will work on getting full set of test results by wednesday. But yes the swg is intex. and I usually run the copper bars when my swg runs.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Again, unrelated to the buildup on the plates, but definitely unplug the copper bars...you do not need copper in your pool that could cause staining or blond hair turning green. Chlorine alone is enough to keep the pool sanitized.
    May 2013
    Chandler Arizona
    78
    why do I want to remove the copper bars? I say you posted this a while back;
    Many companies fall into the trap of pushing the use of copper ions as an algaecide. Some of it stems from the misunderstanding in the industry of the role cya plays in maintaining proper FC levels. If proper FC levels are maintained (for a given cya level) then there is no other chemical needed to keep algae from growing. There is no advantage to leaving the bars on the intex connected if you follow the methods taught here at tfp.
    May 2013
    Chandler Arizona
    78
    I currently dont have any pool staining. or green hair
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You do not need to remove them...unplugging them is probably enough. Like I said in the quote you have from me above, it does nothing to help and eventually the level can build up enough to stain the pool.
    22,542
    Reinforcing what Linen said, If you lave the bars hooked up they keep adding copper to the water. Once you have enough to cause staining the only way to lower it is to replace the water. Also copper stains can be impossible to remove once they've set. And, as mentioned above, it's doing nothing for you so why keep adding it?
