Thread: Intex relief valve
    May 2013
    Chandler Arizona
    78
    Intex relief valve
    is it possible that this little black relief valve on top of my plunger can air in leaf basket and cause pressure to drop? ( when I vacuum this seems to happen every time. Then I have to restart my pump to re-prime etc...
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex relief valve
    I am not familiar with the new intex plunger valve. Is that an anti suction safety valve? If it is, then yes I could see air being sucked into it when if the vacuum line is small/restricted or the flow is restricted at the vacuum head.
    May 2013
    Chandler Arizona
    78
    yes, anti suction safety valve. with the valve taped shut as a test I still get air in leaf basket. would bigger hose diameter help?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Bigger hose may help restrict the flow less...so yes that could help. Also, it is possible once you add the add head loss of the vacuum you start pulling air in somewhere else like the leaf basket cover or the drain plugs or any other joint in the suction side plumbing. With the vacuum attached you could run water over the different joints and see if the air stops.
    May 2012
    Baltimore, Maryland
    183
    if you do not have any problem during normal filtering/skimming with the pump basket staying full, And have the issue with air getting into the pump when vaccuming its most likely the anti-suction valve doing it. you can test this by placing your finger over the nipple for a few minutes and see if your pump basket fills. To solve this problem I drilled holes into the screw on vaccum attachment. A larger diameter hose could also help resolve this.
    15'x4' Metal Frame Intex 3yo (2nd year winterized) 16" 2650gph intex sand filter, Thru wall skimmer, dual inlet/single outlet, 1000gph intex pump (heater) Solar Cover TF-100 testkit, TFPC
