Results 1 to 16 of 16
Thread: Water supply line in my skimmer
    Dec 2012
    Double Oak, Texas
    28
    I have an in-ground plaster pool that has two skimmers. The other day I noticed a white pvc line that entered one of the skimmers from the top and protrudes about two inches straight down into the tunnel just behind the weir. I then found a pvc ball valve in an in-ground round irrigation valve box in my pool equipment area that sends water to the skimmer. Is this a common solution for refilling a pool? Is this intended to feed a auto fill system? If so, is there a float valve that will not obstruct the skimmer?
    Thanks in advance for your help.
    Sam
    21K gal Plaster pool w/ 6 jet Spa, 2 HP Jandy Stealth JHPU2.0 (upgraded to a 2-speed motor) pump for pool/spa, Jandy 60 sqft DE filter, Aquapure 1400 SWG, Jandy Aqualink RS6 Controller. Water feature with Jandy JHPU1.0 Pump, Tiger Shark pool cleaner
    22,551
    Re: Water supply line in my skimmer
    A picture would help, but you're right about it being for filling. The way you describe it being routed doesn't sound like a float valve would work on it.
    Dec 2012
    Double Oak, Texas
    28
    I agree a standard float valve would be difficult with it coming straight down from the top, but I was thinking a Hudson valve might work. What do you think? I'm not sure the Hudson valve is adjustable the way a standard float valve would be, so the install height would need to be correct for the desired water level and changing it later would be harder.
    http://www.hudsonvalve.com/
    Sam
    22,551
    You're right about the adjustment. You'd have to shorten or lengthen the pipe to adjust it.
    Dec 2012
    Double Oak, Texas
    28
    This water line looks like it is a 1" line, and I would like to find the best way to replace the manual pvc ball valve with an automated valve that I can connect to my Aqualink RS. Ideally, I would be able to open the valve for a specified period of time and then automatically turn it off.
    Sam
    22,551
    How about a sprinkler valve? You could program it like a cleaner valve.
    Dec 2012
    Double Oak, Texas
    28
    Sounds like a great idea. Are you familiar with a Jandy Aqualink RS? Would i connect the sprinkler valve to one of the JVA sockets? I think i have a JVA socket open and they are 24 VAC like a sprinkler valve requires.
    Sam
    22,551
    That's what I was thinking.
    Dec 2012
    Double Oak, Texas
    28
    I'm not sure this will work the way we thought. I was just looking at the Jandy manual and it looks like the JVA connector is 3 wire with two of the wires controlling the direction of the valve. They have obviously configured these ports to work only with Valve actuators and not simple on/off valves. Jandy has a sprinkler system module that looks like it will do what I want, but is over $100 and overkill for what I want, but it may be the only decent solution.
    Sam
    38,354
    I am not sure why you could not just connect 2 of the wires to the solinoid valve and then when the "actuator" was switched in the RS, the solinoid would no longer get power and shut off? Or am I missing something?
    I thought one wire is a "ground" and the other 2 provide power (one or the other) for the actuator to move.
    22,551
    JB is correct. Just use the minus (-) and the normally open positive (+) terminal to power the sprinkler valve.
    Dec 2012
    Double Oak, Texas
    28
    Is this something you have seen or heard done successfully? If I understand correctly the JVA port on the RS only supplies power on either the open or close wire long enough to open or close the valve, but sprinkler heads require a constant supply of power to keep the valve open. Am I missing something here.
    Sam
    38,354
    It should continuously provide power. I think there are switches in the actuator that open the connection when the position is met, but power is still available.
    Dec 2012
    Double Oak, Texas
    28
    OK, I think I understand now. Please check my wiring plan.
    The JVA port on the Aqualink RS Power Center has three wires which are Red (Switch Leg), White (Switch Leg), and Black (common). The sprinkler head has two wires and one is to open the valve, and the other is common. If this is correct, I think I understand that both the RED and White from the JVA port need to connect to one of the sprinkler head wires, and the Black JVA lead, connects to the other sprinkler head wire. Do I have this correct?
    Sam
    22,551
    No. You do not want to connect the red and white wires together. That would supply power to the valve all the time. You have the black wire right. I think it's the white wire that you want to hook to the sprinkler valve. If it's on when it should be off, just switch to the red wire.
    Dec 2008
    Houston, TX
    31
    Can you confirm if connecting directly to the valve controller worked? I want to try this with a Hayward Proline valve controller and have seen some conflicting responses. 24 VAC vs 24 VDC problems, etc.
    34 x 16 Free Form Gunite - Tropical Breeze Pebbletec, Color Logic LED Lights, ProLine PS-8 control, Goldline Salt Chlorine Generator, 2hp Northstar 2 spd, 1hp Northstar - sheer descent, Hayward 525 Cartridge Filter, Hayward 400K Low Nox Heater
