Thread: Pool Pilot Check Valve
    I have recently been getting error messages from my Pool Pilot for low pressure. It looks like the check valve is stuck open (it doesn't close when I turn off the pump).
    Any ideas on how I could clear it or a tool that I could use to get down in there and try to move it?
    Guy
    12000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Re: Pool Pilot Check Valve
    Welcome to TFP!
    AutoPilot suggests wrapping the manifold strainer in plastic wrap and running the system for a few minuets to clean out the manifold check valve. Remember to remove the plastic wrap afterwards.
    This did the trick.
    Thanks so much,
    Guy
