Thread: Rinse only DE filter grids ok?
    Hi,
    Do I "have" to soak my filter grids/cartridge after I hose the cellulose/DE off of them. They certainly aren't bright white anymore, but they have only a faint brown discoloration. This is my second year with the filter, and I haven't soaked them yet. Is that bit of dirt really interfering with anything? I imagine the second i reinstall them, and coat them with the cellulose they will get dirty almost immediately.
    Thanks
    16,000 gallon, inground. Diamond bright finish. Hayward 1.5 hp superpump, quad 80 DE filter, Jandy legacy gas heater
    Mar 2010
    Spring, TX
    1,082
    Re: Rinse only DE filter grids ok?
    When I had my DE filter, I just rinsed off the grids and that seem to work for me.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    In eight years, I have only done the full soak routine once. Otherwise I rinse and reassemble. I didn't see much difference even with a soak and acid bath. It's just that after eight years, I felt guilty that I hadn't done the whole routine.
    chiefwej
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I backwash, open the filter, blast off the residual, backwash a little more, and put it all together. I've only taken my filter all the way apart once, and never soaked the grids. My grids are not gleaming white anymore, but they're not crusty and stiff, either, and the pressure's good and it filters great. I'm of the opinion of don't fix it if it ain't broke.
